Help me install ls6 intake? Mt.Belvieu area
Here is where I am at.
Here is my intake.
Make sure you pull the connector and hoses off the back, and disconnect the fuel lines and plug on the driver side. After that all it is disconnecting the injector plugs, and taking all of the 8mm bolts out.
You will probably want to take off the strut tower brace.
I kinda freaked out. Went and got q-tip and oil and tried to get it out. Then went and got vacum cleaner. Think I got most of it. Will I be ok if i run engine for 10-15 seconds then change oil?
Here is the 04 vette valley cover I bought.
Also, my throttle body came in. I think Bo did a good job.
I am a little worried about the debris and 30-40 mesquitos that may be under this towel. I hope I haven't messed up so far.
I also bought a brand new knock sensor wiring harness for $15 from someone off of this board. Let me know if you have any suggestions I am a noob to this.
