Is my '06 Duramax diesel going to pass inspection without a cat?
I've heard/read that diesels don't have to have cat(s). Is this true? I also don't have a muffler, is that going to be an issue too? I have to get an inspection tomorrow and I want to know before I waste my time and money.
Also, aren't diesel inspections good for 2 years and don't have emission testing?
2 No
3 No
4 No
Haha.. Don't have anything on my '99 F350. Gutted cat/no muffler.. Still pass inspection. Maybe because my Dad's friend does it here at the local GM dealership. Oh, and my Dad is about to get certified for state inspection!
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I believe on 07 or 08 and newer they are doing the full inspection on diesels. If it is older it is just a safety inspection. My truck is straight piped and have had it inspected with no problem.
X2 .....if it is factory equppied u must have....i have a 99 straight piped power smoke and it didnt come with a cat so no need...if ur duratrash i mean duramax came with one ...it "should" be there, but when i inspect vehicles that are loud i just what kinda exhaust and how much it cost...if no check engine light is on u will mosty likly be safe...
hahaha ehh the power jokes a lil young for a stroke just yet...its delt with some duramaxes..and also got walked by some haah..got it really cheap really low milliage...so i just put a fmf sticker over the blue oval.haha
You will fail with an 06. I have the same truck. Because of the new emissions laws you have to have a cat and a muffler. I believe they scan the computer to see if there are codes set which is pretty common if you delete the cat and don't turn that off in the computer (or put a finger stick in line). The inspector can also look underneath which is pretty likely. Only the original inspection is good for 2 years. Afterwards it is every year. I have not hit that point yet so I have not had mine done. That is why I am not certain if they test the tailpipe or just scan the computer.
Did you hang on to your factory exhaust? I would just stick that back on and go get it inspected.
Ok, so I took it to Kwik Kar yesterday evening at 5:30 pm (closes at 6:00 pm) and they whipped right through it. Literally less than 15 minutes. I just washed my truck Sunday, so it was clean when I rolled up there. I figured they just saw a newer truck, in tip top shape, with a bunch of add-ons, etc. that they knew there wouldn't be anything wrong. All they did was flash the high beams and do the turn signals. I'm not even sure if they plugged it into the computer.
LeadfootDuramax, when I used to have the Predator tuner, I had a Fingerstick/EGR blocker plate. But when I stepped up to a real programmer (PPE), it has an automatic EGR disabler, so I ditched the Fingerstick. PPE or EFI Live is the only way to go, but the PPE is hands down the best handheld. I have no codes.
How does your tranny like the PPE? Are you running a Transgo Jr kit??
