wtt: UNScreened maf for screed Maf
MAFs that have had the screens taken out or are ported can be a pain in the *** to tune. It can make all kinds of weird **** happen. It happened to a truck that had a maggy up at GForce the problem ended up being the MAF. Also the CFM difference between having the screen Vs not is not a big enough difference to worry about. Also the screen in the MAF works to channel the air into streams removing turbalance and tumble.
Thomas
Thomas
Thomas
Thomas
HAHAHAHAHHAh Find another tuner dude..you've got a 6 speed. Descreening doesnt effect them as much like it does A4 cars.
Looking at my tables my MAF is doing some weird stuff and actually maxed out. It's worth a shot to see if my tuner can pick up some HP with it, if not I'll sell it to a shaner customer.
1 Post
SD tunes are fine as well. My car was tuned using LS1 edit, but HP and whatever else is fine as well it just depends on what the tuner has etc. I use an 85mm ZO6 MAF with my setup, and have never had a problem. I also used a ported stock and descreened one on my car, and did the trick where you make it think it is always 59 degrees outside. I never had a problem, and it worked great while my car was mostly stock.
Lol come on guys I know for a fact some of you have seen some of the port jobs of MAFs, and well thats all that needs to be said.
Thomas
Thomas
#34
Shaner is fine tuner and knows his **** if you want to talk smack about him why dont you talk it to his face hear is his number give him a call (900)NOT-A-SPONSOR
#35
he is tuning my car and pat-ws6 car. his tune is much better streetable then a dyno tune. I you do so happen to call him be prepared to talk for hours he will shut you up real quik or tell you to get the **** out of his house. Dont think he won't either!!!!
#37
There own personal cars speak for themselves. Mine didn't have driveability issues and ran deep 6's on the stock long block...NEXT!
#40
But still the OP is looking for a maf , if you don't have one move along..
