Blew Motor Up
Yeah, they put that ''hole in the block tune'' I'm waiting for them to put that one in mine. LOL!!!!
You had a part fail or you did not check your clearances when you did the install. It is pretty much impossible that your "horrible tune" caused your motor do come apart. There was a mechanical issue that I am sure was made worse by several dyno pulls and it strated running worse and worse till it let go on your way home. It was just bad timing for RPM and bad luck for you.
I hope you post up what you find when you take it apart. Im sure you are going to find a dropped valve that went through the piston.....either from you not fly cutting, or a broken valve spring......
And truefully I don't see how I am talking so much crap... I was just stating the facts that was put before us...
I guess since my car only runs 12's that must put me at something like a newbie???
Dude post more than 4 times, before you start talking crap...
I was just thinking the same thing.
