Engine Bay Cleaning
Old Dec 27, 2007 | 04:50 PM
julianchaz's Avatar
Default Engine Bay Cleaning
What is the best way to clean and detail an engine bay?
Old Dec 27, 2007 | 04:53 PM
954mula's Avatar
Browse the Appearance & Detailing section.
Old Dec 27, 2007 | 05:02 PM
Inspector12's Avatar
TT-TECH Veteran
Yeah the car wash with the high presure soap is the best thing that I use no special chemicals or anything. Don't worry about anything getting water in it and not starting. Have fun.
Old Dec 27, 2007 | 05:15 PM
kmgsix08's Avatar
really? i thought you had to worry about that. i've always been scared of it happening
Old Dec 27, 2007 | 05:18 PM
julianchaz's Avatar
same here. I have just worried about the water getting into things.
Old Dec 27, 2007 | 05:32 PM
kmgsix08's Avatar
but then again when i was a detailer at moritz cadillac and bmw, they always told us to spray the engine down with a power washer and i never had a problem there
Old Dec 27, 2007 | 05:38 PM
TchargedLS1TA's Avatar
I use Simple Green. Make sure the engine is cold and soak the motor with pure Simple Green. Let it sit for a few minutes then use your garden hose and a little bit of pressure to rinse it off.. Does wonders, but sometimes leaves the intake manifold with some white ***** on it- easy enough to fix with WD40 on a rag
Old Dec 27, 2007 | 05:48 PM
RickyMartinZ28's Avatar
Everytime I've washed mine it didn't start for a day. Damn Opti.
-Rick
Old Dec 27, 2007 | 06:40 PM
67Ranger's Avatar
Like they said, spray it down with a pressure washer and soap. Then you can use low pressure to rinse it. You can also start it up for a min or so, until it gets just a little heat in it, then spray it down with foam tire cleaner, and wipe everything down. It should look really nice after that.
Old Dec 27, 2007 | 06:48 PM
DopeFedZ's Avatar
Diluted Simple Green. I wash it everytime I wash my car which is at least once a week. I don't wrap or cover anything just spray it down afterwards with the hose and air dry it with the compressor.
Old Dec 27, 2007 | 07:55 PM
TT-TECH Veteran
Lt1 some have the leaking opti never has any issues with either the 94 or the 96 though. 98+ never had as single issue and it is what I do every time you won't have any issues I have never had any need for any other soaps, but if you like, but some will stain alumium and make it look oxidized and I haven't cared to try and see which ones will and won't never had any need. Good luck.
Jeff
Old Dec 27, 2007 | 09:57 PM
I would not reccomend this unless you are at home. If you arat a car wash and your **** dont start, better make sure you have a buddy that will pick you up
Old Dec 27, 2007 | 10:25 PM
TT-TECH Veteran
So you've done it right? Look all of the factory conectors are weather pack conectors so as long as you are not trying to blow the conectors apart etc... It doesn't have any effects on the car. These are not the old school vehicles that had distributers and points that had to dry if you got water in them. But hey do what you want I will continue to do it as I have since 1985 with my mothers TPI car etc...
Old Dec 27, 2007 | 11:00 PM
STS95T/A's Avatar
what you need is a bottle of simple green, a tooth brush (for the painted stuff), a wire brush, and about 3 hours.
i went ocd on my trans am a few years and it looked great
but if you don't want to waist that much time a pressure washer will work just remove your air filter and put a bag over tha hole where the filter was to keep water off of it. that is if you have a cold air intake.
robbie
Old Dec 28, 2007 | 12:12 AM
BizZzatch350's Avatar
Moderator
I have heard of people using steam cleaners as well.
Old Dec 28, 2007 | 02:23 AM
Gun5's Avatar
steam cleaning is the best but not everyone has access to it.... there is some badass company that makes one can do AC vents to its nuts
Old Dec 28, 2007 | 03:49 PM
julianchaz's Avatar
Smile
thanks for all the help
Old Dec 28, 2007 | 03:57 PM
You're right, there weather pack connectors, designed to prevent moisture from getting inside, but not to prevent a 1000psi blast from a pressure washer.
I simply stated what I did as a friendly reminder what may happen
Old Dec 28, 2007 | 06:57 PM
TT-TECH Veteran
You right what ever he wants to do is fine.
