Anyone else play this game when they are bored?
#101
Best Setups For The Game!
These are just about all the best setups for the cars. If it says ICHIBAN LIMITED EDITION you will have trouble finding that part.
689.82/516.88 GS-R
M Tune Billet Motor Mounts
Takayami Racing Sport Coilover Kit
Pole Position 2" 4 Point Cam Lock Harness
Nitto 1320 Drag Slicks
Ride Grafix Horizon
HRE 441R 17"
Pole Position Fitt Racing Seats (Black)
Pole Position Racing Hood Pins
Zintek Z Clutch
Kobi Stage 3 Flywheel
Shocke Lite Battery
DataPro Pro ECU
Onzo K7 Spark Plugs
Kobi X Cam Gears
Taxidy Core Camshaft
Kobi PRO Connecting Rods
Hunter Dura-made III Crankshaft
Takayami Super-Flo Intake Manifold
Kobi Competition Throttle Body
Gugem Competition Oil Cooler Kit
Suprec Fang Oil Pump
Kobi 8:1 Racing Pistons
Taxidy Valve Springs and Titanium Retainers
Yukomi Competition Valve Kit
Blowfish B series B.O.V.
Motiv Arctic Intake 4.25"
FastFlow R-T Air Filter
Gasman 225 Shot Fogger
Gugem Competition Pipe 100mm
Gugem Racing Muffler 100mm
Yukomi Ultra Exhaust Piping 100mm
Kobi Spec 2 Fuel Rail
Takayami 1000cc Injector Set
Gugem Competition Fuel Cooler
Formuline Air/Fuel Controller
Formuline Single 10lb Carbon Fiber Bottle
FireShield Racing Thermo Wrap
Skoei G78 Head Gasket
Skoei Type-4 Block +0.4L
DaBest XR Boost Controller
Formuline Air Fuel Meter
Tronsit Compact Fuel Pressure Regulator
Netron 4 Gallon Fuel Cell
Gugem Competition Fuel Pump
Blowfish R II Piping
DaBest Signature Series XL5 Intercooler
Takayami Power III Turbo 35 PSI
Takayami T472 Down Pipe
Blowfish E65 Turbo Exhaust Manifold
K20A2 (Engine)
688.99/516.25 GS-R
Drifz 505 GM 18"
RL Design Altezza Taillights
Zintek Z Clutch
Shocke Lite Battery
DataPro Pro ECU
Onzo K7 Spark Plugs
Kobi X Cam Gears
Kosen Stage 2 Valves
Formuline 2 Bottle Kit. 15lb Carbon Fiber Bottles
Formuline 200 Shot Nitrous Jets
K20A2 (Engine)
704.89/528.17 GS-R
Pole Position Fitt Racing Seats (Red)
BBS LM 20"
Ichiban Drag Launch Kit
MRG Sports Stage 3 Clutch Kit
Motiv Ultra-Light Flywheel
Onzo K7 Spark Plugs
L2 Engine Management System
Shocke Lite Battery
Kobi X Cam Gears
Gugem Racing Head Gasket
Suprec Fang Oil Cooler
DaBest Signature Series XR B.O.V.
Kobi Racing Connecting Rods
TRM RS-Ti Titanium Piping 4.00"
Ichiban Limited Edition Turbo
DaBest Signature Series XL4 Intercooler
J-Tech Pro Pipe Kit, Type B
Ichiban Limited Edition Nitrous Jet
Ichiban Limited Edition Injectors
Ichiban Limited Edition Valve Springs
Ichiban Limited Edition Intake Manifold
Motiv Arctic Intake 4"
L2 Racing Air Filter
Formuline 2 Bottle Kit. 10lb Carbon Fiber Bottles
K20A2 (Engine)
623.39/597.77 EVO
Drifz 505 GM 20"
OEM Complete Axle Set
OEM Spark Plug Cable Set
Gugem Comp Series Intake Manifold
MNK Racing 6 Pad Clutch Kit
Gugem Competition Battery
TRM REV-Manage System
Onzo K2 Spark Plugs
Gugem Elite Cam Gears
Hunter Dura-made III Connecting Rods
Blowfish FI Camshafts
Hunter Dura-lite III Crankshaft
Hunter Dura-made III Block +0.4L
Takayami Race Cylinder Head
Tokiya Ultra Tight Seal Head Gasket
Gugem Competition Throttle Body
Skoei SportTune Oil Cooler Kit
J-Tech Race Oil Pump
Suprec 8:1 compression TRB Pistons
Kosen Complete Valvetrain Set
Takayami 100mm Open Race Pipe
Niome Pro Circuit Exhaust Muffler 4.00"
Yukomi Turbine Tube
Takayami Turbo Exhaust Manifold
Blowfish Z series 42PSI Turbo Z80-42
Netron 8 Gallon Fuel Cell
Tespo E-95 Fuel Pump
Gugem Competition Fuel Rail
Takayami Mega Flow Intake Filter
TRM RX Intake 100mm
Blowfish FI Intercooler
Enjin Turbo-Z Valves
TRM RS-Ti Titanium Piping 4.25"
4G63 (Engine)
630.09/604.21 EVO
Factory 21 Sway Bar Set
HRE 441R 20"
Ride Grafix Horizon
Onzo K2 Spark Plugs
Yukomi Turbine Tube
TRM EVO-Manage System
TRM RX Intake 100mm
Ichiban Limited Edition Spark Plug Cables
Ichiban Limited Edition Valves
Ichiban Limited Edition Camshafts
Ichiban Limited Edition Pistons
Ichiban Limited Edition Catalytic Converter
Ichiban Limited Edition Intercooler
TRM RS-Ti Titanium Piping 3.75"
4G63 (Engine)
1040.24/1155.20 Mustang GT
Nitto NT 555R
HRE 441R 20"
X Motorsports Pro Launch
Radiant Compact Fuel Cooler
Techoline Race Fuel Pump
Enjin Pro II Intake Manifold
Onzo K7 Spark Plugs
Shocke Lite Battery
Suprec Fang II Cam Gears
Taxidy Max Crankshaft
Taxidy Mach Cylinder Block +0.4L
Stealth Low Compression Pistons -2.5:1
Kobi Racing Throttle Body
Skoei Race Oil Cooler
Kobi Spec 1 Fuel Rail
Gasman 250 Shot Fogger
Blowfish E70 Turbo Exhaust Manifold
Ichiban Limited Edition Air Filters
Suprec Boost Controller
Ichiban Limited Edition Muffler
Ichiban Limited Edition Down Pipe
MRG Sports Port and Polished Head
Kosen ProFlow Cat. 90mm
DataPro GT-Pro ECU
Jetsun Speed Valve Springs
Dilat TV8 Performance Rods
TRM Racing Spec Piping
FastFlow 4" steel piping
99H (Engine)
994.11/1103.96 Mustang GT
ICW Racing 830 MB Sic Tuner 20"
Shocke Lite Battery
DataPro GT-Pro ECU
Onzo K7 Spark Plugs
Taxidy Max-Light Connecting Rods
Suprec GT 3 Cylinder Heads
Kosen Stage 3 Valves
Kosen ProFlow Cat. 95mm
TRM SP2 Exhaust Muffler 4.25"
Niome GT-V Down Pipe
Blowfish ZX Series 38 PSI Turbo
Reed Filters Hi-Flow Air Filter
CellSpeed 8 Gallon Fuel Cell
99H (Engine)
689.82/516.88 GS-R
Ride Grafix Horizon
HRE 441R 17"
Zintek Z Clutch
Shocke Lite Battery
DataPro Pro ECU
Onzo K7 Spark Plugs
Kobi X Cam Gears
K20A2 (Engine)
688.99/516.25 GS-R
Drifz 505 GM 18"
Zintek Z Clutch
Shocke Lite Battery
DataPro Pro ECU
Onzo K7 Spark Plugs
Kobi X Cam Gears
K20A2 (Engine)
704.89/528.17 GS-R
BBS LM 20"
Onzo K7 Spark Plugs
Shocke Lite Battery
Kobi X Cam Gears
K20A2 (Engine)
623.39/597.77 EVO
Drifz 505 GM 20"
Onzo K2 Spark Plugs
Yukomi Turbine Tube
TRM RX Intake 100mm
4G63 (Engine)
630.09/604.21 EVO
HRE 441R 20"
Ride Grafix Horizon
Onzo K2 Spark Plugs
Yukomi Turbine Tube
TRM RX Intake 100mm
4G63 (Engine)
Nitto NT 555R
HRE 441R 20"
Onzo K7 Spark Plugs
Shocke Lite Battery
DataPro GT-Pro ECU
99H (Engine)
Shocke Lite Battery
DataPro GT-Pro ECU
Onzo K7 Spark Plugs
99H (Engine)
#102
Setups #2
861.52/844.64 G35
HRE 441R 20"
Rival Auto Open Grille
Blowfish E45 Turbo Exhaust Manifold
Blowfish FI Race Head
Gasman 300 Shot Fogger
Takayami Huge Flow Intake 100mm
FastFlow GTS Filter
DaBest Signature Series XL5-PRO Intercooler
Gugem Competition Pipes 100mm
Onzo K4 Spark Plugs
Suprec 11 Gallon Racing Fuel Cell
TRM PowerLine II Battery
CellSpeed Programmable ECU
Motiv Competition Cams
Tokiya CX 2 Connecting Rods
Gugem Competition Crankshaft
Gugem Competition intake Manifold
X Motorsports Big Throttle Body
Enjin Performance Oil Pump
Niome Full Race Valve Springs
Flips T-Comp Valves
J-Tech Pro Pipe Kit, Type A
Takayami Fuel Pressure Regulator
Gugem Competition 2 Fuel Pump
Kobi Racing Spec Fuel Rail
Niome Elite IX Turbo 35 PSI
TRM RX Muffler 100mm
Tokiya EV-3 Cylinder Block
VQ35DE (Engine)
1304.75/1218.83 FORD GT
HRE 441R 20"/21"
Monarch Drag Muffler 4.00"
Techoline 4 Gallon Fuel Cell
Taxidy Mach Cylinder Head PurFlow
MNK Racing Full Race Clutch Kit
DCR Performance ComLite II Flyweel
Suprec XB Head Gasket
Onzo S8 Spark Plugs
DataPro GT-Pro ECU
FastFlow Performance Air Filter
Monarch Drag Cat. 4.25"
Dynasty Race Exhaust Manifolds
Vulture Fuel Cooler GT-2
Monarch Peak Fuel Pressure Regulator
Monarch Peak Injectors 1000cc
Enjin Tornado Intake 95mm
FlowForce 21psi Supercharger Upgrade
Hunter Dura-made VI Crankshaft
Jetsun Deluxe Oil Cooler
Formuline 300 Shot Nitrous Jets
Tespo JL-50 Fuel Pump
Ichiban Limited Edition Throttle Body
Ichiban Limited Edition Piping
Ichiban Limited Edition Fuel Rail
Ichiban Limited Edition Cam Gears
Formuline Speed IV Cams
Blowfish Lightweight Supercharger Pulley
Enjin BK Series Valves
Jetsun Ver2 Valve Springs
Blowfish FI Pistons
Dilat Bro-M Block
MOD (Engine)
1284.99/1200.38 FORD GT
HRE 547R 20"/21"
Onzo S8 Spark Plugs
Shocke Lite KV4 Battery
Monarch Saturated High Impedance Fuel Injectors
Monarch Drag Muffler 4.25"
Jetsun Deluxe Valves
DaBest Race III Piping 4"
Blowfish FI Pistons
Dilat Bro-M Block
MOD (Engine)
688.99/516.25 RSX-S
HRE 547R 20"
Zintek Z Clutch
Shocke Lite Battery
DataPro Pro ECU
Onzo K7 Spark Plugs
Kobi X Cam Gears
K20A2 (Engine)
1126.15/1159.68 Corvette
HRE 547R 20"/21"
Techoline R12 Cam Gear Set
Formuline Full Band Air Fuel Meter
Onzo K7 Spark Plugs
Formuline Speed III Cams
Skoei T5 Head Gasket
Brosec Magnum Throttle Body
Flospeed Thunder Headers
Suprec Fang Pulley Set
Suprec ZS Fuel Rail
X Motorsports Lightweight Axle Set
DaBest Free Flowing Cylinder Head
Hunter Dura-made IV Connecting Rods
DataPro Pro ECU
Monarch Drag Muffler 3.75"
FlowForce 25 PSI Supercharger
Dragon Sports RaceMax Intake 2.75"
LS2 (Engine)
1255.72/1273.74 Corvette
HRE 547R 20"/21"
OEM Spark Plug Cables
DataPro Pro ECU
Onzo K7 Spark Plugs
Suprec ZS Fuel Rail
Ichiban Limited Edition Supercharger
Dragon Sports RaceMax Intake 4.25"
Ichiban Limited Edition Fuel Pump
Ichiban Limited Edition Clutch
LS2 (Engine)
HRE 441R 20"
FastFlow GTS Filter
Onzo K4 Spark Plugs
Flips T-Comp Valves
VQ35DE (Engine)
HRE 441R 20"/21"
Onzo S8 Spark Plugs
DataPro GT-Pro ECU
Blowfish FI Pistons
Dilat Bro-M Block
MOD (Engine)
HRE 547R 20"/21"
Onzo S8 Spark Plugs
Blowfish FI Pistons
Dilat Bro-M Block
MOD (Engine)
688.99/516.25 RSX-S
HRE 547R 20"
Zintek Z Clutch
Shocke Lite Battery
DataPro Pro ECU
Onzo K7 Spark Plugs
Kobi X Cam Gears
K20A2 (Engine)
HRE 547R 20"/21"
Onzo K7 Spark Plugs
Suprec ZS Fuel Rail
DataPro Pro ECU
LS2 (Engine)
HRE 547R 20"/21"
DataPro Pro ECU
Onzo K7 Spark Plugs
Suprec ZS Fuel Rail
LS2 (Engine)
#103
Best Setups #3
688.99/516.25 Integra Type-R
BBS LM 20"
Shocke Lite Battery
Onzo K7 Spark Plugs
Kobi X Cam Gears
L2 H-Fuel Regulator
Flips Competition Valve Set
K20A2 (Engine)
727.23/513.03 S2000
RL Design Vented Hood Type II
Drifz 505 GM 20"
MNK Racing Spark Plug Cables
Tronsit X-Factor Plugs
Netron Oil Pump
Suprec XA Head Gasket
Takayami 75mm Open Race Pipe
Tespo 800cc Extra-Flow Injectors
Netron Power Fuel Rail
Netron 8 Gallon Racing Cell
Takayami T-X3 Intake System 85mm
Skoei Type-7 Connecting Rods
Gasman Single 15lb Aluminum Bottle
Gasman 75 Shot Fogger
X Motorsports Chromoly Axle Upgrade Kit
T-Grip Heavy Duty Clutch Kit
Zintek ECU Chip SF5
Suprec Fang Cam Gears
L2 VTEC MAX 5 Cams
Suprec XV4 Crankshaft
Skoei Type-6 Block +0.4L
J-Tech T-52 Head
Takayami T359
Blowfish Z Series 38 PSI Turbo
Blowfish F series B.O.V.
Takayami TEM62 Manifold
Blowfish H40 Super Intercooler
MRG Sports Racing Flywheel
N's Racing N1 Racing Muffler 80mm
Jetsun Freeze Fuel Cooler
J-Tech T5 Pump
J-Tech Fuel Pressure Regulator
Takayami ZR14 Limited Edition Super Flow Filter
Enjin Low Compression Pistons -2:1
Enjin High RPM spring set
Enjin VX10 Throttle Body
Enjin GXV Valves
F22C (Engine)
1256.38/1361.61 Viper
HRE 547R 20"/21"
Ichiban Drag Launch Kit ver 1
Onzo K7 Spark Plugs
Techoline R15 Cam Gear Set
Flips T-Comp Valves
Stirge Power Pulleys
Gasman 100 Shot Fogger
Motiv Competition-R Camshafts
Enjin VX3 Oil Pump
Formuline 12 PSI Supercharger Kit
Stirge Pro M Connecting Rods
DataPro Stand Alone ECU
CellSpeed Lightweight Fuel Cell
TRM RS Filter Kit
Dragon Sports Pro Intake 4.25"
TRM Titanium Exhaust Muffler 3.50"
Ichiban Type A Cylinder Block
Ichiban Type A Cylinder Head
Axe Racing Lightweight Race Header
Kosen High Flow Cat 100mm
V10-8.3L (Engine)
1065.55/1154.80 Viper
ICW Racing 830 MB Sic Tuner 20"/21"
Enjin VX3 Oil Pump
MRG Sports Stage 2 Clutch Kit
Breeze 3.00" Intake Pipe
Onzo K7 Spark Plugs
Flips T-Comp Valves
Ichiban 15 PSI Supercharger Upgrade
Axe Racing Dura Head Gasket
CellSpeed R-Spec ECU
V10-8.3L (Engine)
983.87/1066.28 Viper
HRE 547R 20"/21"
Takayami MaXX Coilovers
Onzo K7 Spark Plugs
Flips T-Comp Valves
Enjin VX3 Oil Pump
Blowfish FI Cylinder Head
Brosec Magnum Cat 2.75
TRM RS Filter Kit
Gasman Single 5lb Aluminum Bottle
Axe Racing Performance Clutch
Suprec 9:1 compression Pistons
Axe Racing Titan Intake 4.0"
Axe Racing Aero Muffler 3.50"
V10-8.3L (Engine)
800.46/889.09 TC
HRE 547R 17"
OEM Clutch Kit
Netron Oil Pump
Kosen Supreme Exhaust Test Pipe
Techoline Race Fuel Rail
FastFlow 3" Steel Piping
Takayami TougeMaster Sport Muffler 2.5"
MNK Racing Inferno-Wrap
X Motorsports Stage 1 Axle Kit
DaBest High-Strengh Battery
Gasman 150 Shot Fogger
Ichiban Spark Plug Cables
MNK Racing Elite Iridium Spark Plugs
FastFlow BTS Block
Takayami VissMAX Cylinder Head
Flospeed MaxFlow Intake Manifold
Kosen VRE Valve Springs and Retainers
Suprec 9:1 Compression Supreme Pistons
Enjin PF Valve Kit
Takayami Stainless Turbo Manifold
TRM 4.5" Exhaust Piping
Ichiban 3198 Down Pipe
Blowfish SS Series BOV
Enjin EJN Intercooler
Blowfish T Series 32PSI Turbo
Ichiban 1600cc Injectors
Tespo Maxx Fuel Pressure Regulator
Gasman G1000 Fuel Pump
Enjin Tornado Intake 115mm
L2 High Flow Cone Filter (large)
Suprec Extreme Cam Gears
Ichiban Max Bore Throttle Body
DataPro D400 Stand Alone ECU
Ichiban Competition Camshafts
Taxidy Billet Connecting Rods
Takayami HG5 Gasket
Netron 4 Gallon Racing Cell
2AZ-FE (Engine)
952.03/983.11 Supra
Ichiban HurricaneX Intake 110mm
Breeze MaxFLO Turbo Piping
Blowfish Z Series 38psi Single Turbo
Takayami Sequential Blow Off Valve
Blowfish FI Down Pipe
Ichiban Pro Cam Gears
Enjin Xtreme Head Gasket
Enjin VX50 Throttle Body
Enjin 8:1 compression pistons
Netron 5 Gallon Racing Cell
Clutcher Extreme Clutch Kit
X Motorsports 90mm Straight Pipe
Ichiban Full Titanium 4.25" Muffler
DataPro Air Fuel Meter
DaBest DB-R Boost Controller
Formuline 150 Shot Nitrous Jets
Flospeed Fuel Cooler
J-Tech Billet Fuel Rail
Winning MaxX Intake Manifold
Netron Oil Pump
Takayami S Pro Springs
Ichiban Supreme Axle Set
Enjin Super High Flow Kit
Dash Sport S Camshafts
TRM PowerLine Battery
DataPro ECU Chip Stage III
Suprec XR Crankshaft
Yukomi Y1000 Fuel Pump
Blowfish H80 Super Intercooler
2JZ-GTE (Engine)
BBS LM 20"
Shocke Lite Battery
Onzo K7 Spark Plugs
Kobi X Cam Gears
L2 H-Fuel Regulator
K20A2 (Engine)
727.23/513.03 S2000
Drifz 505 GM 20"
Netron Oil Pump
Zintek ECU Chip SF5
L2 VTEC MAX 5 Cams
J-Tech T-52 Head
Takayami T359
J-Tech T5 Pump
Enjin GXV Valves
F22C (Engine)
HRE 547R 20"/21"
Onzo K7 Spark Plugs
Flips T-Comp Valves
Enjin VX3 Oil Pump
TRM RS Filter Kit
V10-8.3L (Engine)
Enjin VX3 Oil Pump
Onzo K7 Spark Plugs
Flips T-Comp Valves
V10-8.3L (Engine)
HRE 547R 20"/21"
Onzo K7 Spark Plugs
Flips T-Comp Valves
Enjin VX3 Oil Pump
TRM RS Filter Kit
V10-8.3L (Engine)
800.46/889.09 TC
HRE 547R 17"
OEM Clutch Kit
Netron Oil Pump
FastFlow BTS Block
Enjin PF Valve Kit
Takayami HG5 Gasket
2AZ-FE (Engine)
952.03/983.11 Supra
Netron Oil Pump
2JZ-GTE (Engine)
#106
alright, for the people starting out, i will hook you guys up with Rims and Slicks and my 1 gear ratios. They will help you save for a new car. Youll first have to move to 2nd city, cost is 3k, then Ill hook you up with that stuff. Basically Ill help you if you have a stock teggy and stock rims and are having a hard time starting out.
If you have money I can get you parts from the upper citys just let me know. I get membership prices too. Also if you already have some money then Ill mod your car using your money to make it consistant. Im not rich lol. But I am hooking people up. Im kinda stuck because when I get money I end up spending it to help others lol.
#107
#115
I just joined, Craz1469............about to start doing work. I pm you and the team. How do you start making money?
Edit: Nevermind
Edit: Nevermind
