head install but damn the driver header is a B!
William
I was able to move the header far enough away. Make sure it isn't still connected to the Y or X pipe.
or method two go underneath the car with the steering wheel centered get an 11mm socket or wrench and loosen and remove that bolt the holds the steering shaft make sure you dont turn the wheel or put it back exactly as it was removed or your airbag wont work (sir coil will break) and loosen but dont remove the other 11mm bolt on the sam shaft up top near the brake master cylnder
if you need more help let me know
