Wilson 95mm throttlebody, Efi sheetmetal elbow
![](https://webspace.utexas.edu/xssive/IMG_1829.jpg)
![](https://webspace.utexas.edu/xssive/IMG_1828.jpg)
![](https://webspace.utexas.edu/xssive/IMG_1827.jpg)
Powdercoated black sheetmetal elbow and a Wilson Manifold 95mm billet throttlebody. The elbow has 1/4" and 1/8" bungs tig welded on.
Also included is an adapter to run a gm IAC. The ford tps sensor and IAC valve will also be included.
All of this has 0 miles, brand new.
Here is what is cost to put together:
Sheetmetal 4150 elbow - 220
Powdercoating = 80
WIlson Throttlebody = 370
ASSC IAC adapter plate - 80
GM IAC motor - 72
Ford TPS sensor - 45
Total = 865
I will seperate this to the elbow an throttlebody if needed.
Throttlebody with all the sensors and adapters - 500$
Powdercoated elbow- 190$
Or... 670 for both
