f/s 92 calypso coupe
SOLD. rare CALYPSO GREEN coupe Original V8/ Tremec TKO.
MAC 2.5" Prochamber
Magnaflow stainless 2.5" cat-back
COOLING, FUEL & IGNITION -
BeCool 4 core aluminum radiator
SN-95 fan, wired with relay and a manual switch
MSD 6AL
Blaster TFI coil
MSD wires
MSD 2-step (not installed)
Weldon 255 intank pump
WHEELS & TIRES-
Weld Rodlites, 15x4, 15x8
165R15 radial fronts
275/60-15 BFG drag radials
MISC-
Silver-faced gauge cluster
NEW 6-pc headlamp set w/ clear sides
Proform adjustable shift light
Alpine C/D player
Optima red-top battery in the trunk
Engine-
306, stock crank/rods. flattop pistons
Probe main support, all ARP fasteners
ported Edelbrock Performer RPM intake-1262 gasket size
ported Canfield 192cc Heads, 2.02/1.60
FelPro 1011-2 headgaskets
Ford Motorsport valvecovers
Comp XE274HR camshaft
Scorpion 1.6RRs
NEW Crane hydraulic roller lifters
NEW Comp valvesprings, p/n 986-16
Comp pushrods
Moroso 7QT pan
Melling High Pressure oil pump
Chromeoly pump shaft
Professional Products balancer
polished 70mm EGR
BBK 70mm T/B
BBK cold-air kit
C&L 75mm Mass Air
24# Motorsport injectors
March underdrive pullies
March bling-bling alternator bracket
FRPP breather
FRPP power steering relocation kit
NEWer plugs, cap, rotor, TFI module, Synchromesh, Q-synthetic 10w30 oil, diff fluid, coolant, etc...
DRIVETRAIN-
Tremec cast bellhousing
new center force cluch
Tremec TKO
Steeda Tri-Ax shifter w/ 35th anniv ****
FRPP aluminum driveshaft
Driveshaft loop (not installed)
8.8 w/ Auburn Pro
31 spline Moser axles w/ 3" studs
MAC rear end girdle
SUSPENSION & EXHAUST-
Koni 5-way struts
Eibach front drag springs
V-8 rear springs
KYB rear shocks
Maximum Motorsports uppers & lowers
New Delrin LCA bushings
BATTLEBOXES lower Tq box plates
MAC 1-5/8" longtube headers
asking $9000 obo call SOLD or trade for 98-02 camaro z28/ss
MAC 2.5" Prochamber
MSD 6AL
Blaster TFI coil
MSD wires
WHEELS & TIRES-
MISC-
Alpine C/D player
Engine-
Scorpion 1.6RRs
Comp pushrods
Moroso 7QT pan
polished 70mm EGR
BBK 70mm T/B
BBK cold-air kit
C&L 75mm Mass Air
FRPP breather
DRIVETRAIN-
Tremec TKO
8.8 w/ Auburn Pro
MAC rear end girdle
Koni 5-way struts
V-8 rear springs
KYB rear shocks
does it come with the coil wire? LOL
and this is not just another mustang! I wish I could make room for this coupe I'd be all over it like Kobe Bryant on a hotel housekeeper....
Bump for a clean *** calypso coupe!!
