question
Old Apr 10, 2008 | 07:16 PM
SILVER SS 00's Avatar
Default question
well my question is i have a 408ci,all stroker internal,big e cam,90/90 set up with nw tb,30lbs injectors (ford racing),mti stage 3 heads (cnc) 650 springs,weisco pistions (4cc) hellfire rings,4.00 lantiu crank,running a 12:1 compresion,well my question is everytime i spray gas on it it does not give me u full shot,it sputers it,i have a 255 in take fuel pump,do i need a bigger fuel pump? hope you guys can help me out
Old Apr 11, 2008 | 01:26 AM
Gold Z's Avatar
If you are using a dry kit you are probably maxing out your injectors.
Old Apr 11, 2008 | 02:58 AM
Brian2006's Avatar
Agreed. There are calculators listed in the fuel and injection forum to determine what size injectors to get. I would assume 42lb injectors would suffice.
To answer the OP question, I think it'd be safe to say it's time to upgrade the fuel pump. You don't wanna worry about the pump everytime you go WOT. It's better to be safe than sorry
Old Apr 11, 2008 | 07:19 AM
it is a wet kit
what pump would you recommend
Old Apr 11, 2008 | 07:21 AM
Mike TexaSS's Avatar
8 Sec Tuner
Give us a call. I got you covered!
Old Apr 11, 2008 | 08:52 AM
Randy_S's Avatar
Mike will take care of you.
It sounds like you need to upgrade your injectors. I have the same exact motor as you EXACT and I run 42lb injectors.
Old Apr 11, 2008 | 09:17 AM
Mike96z's Avatar
#1: your injectors are too small for that engine, you need atleast a 46# set. Find an injector calculator and youll see, my 388 almost maxed out my 42#ers.
#2: you need to switch or upgrade that kit to wet, if you wanna run the kit as a wet kit, just get the solenoids and tap into the fuel line before it hits the fuel rail, that way you dont need bigger than above stated injectors. Otherwise youd have to have some injectors probably almost double that size to compensate for different shots im guessing.
#3: 12:1:1 is on the edge of 93 octane. yes with an aluminum head you can get away with it........... that is if you are running an aluminum head, if you arent, get it tuned for 93 but run a higher octane when you can.
Old Apr 11, 2008 | 09:22 AM
Mike96z's Avatar
here are a couple of fuel injector calculators, you need to enter engine hp and add the hp gain from the nitrous to that to make sure you have enough fuel. IE. 400hp and a 100 shot, do the max of 500hp even though you may not get the full 100 out of the nitrous but if you will be upgrading to a bigger shot in the future then make sure you have a bigger injector or just buy new ones later and sell the current ones you get.
http://www.rceng.com/technical.aspx
http://www.iroczone.com/calcs/injectorsize.htm
Old Apr 11, 2008 | 05:01 PM
thanks guys for the help
who do i ask for when i call
Old Apr 11, 2008 | 06:32 PM
Shackleford's Avatar
Mike.
Old Apr 11, 2008 | 06:56 PM
ok well now i am looking for 42lb injectors,let me know if you have any for sale
