Royal Purple Vs Regular Synthetic Oil
Is that formulated for diesel motors? I'm pretty sure you need a different type of oil for optimum results in diesel. I'm sure you can run regular oil, but I'm pretty sure you get longer life from oil formulated around diesel motors. I know in my Duramax I could go around 10k on an oil change & I used Chevron Delo or Shell Rotella.
rp contains alot of detergents, which will take the wax buildup off of your seals usually put there by other oils. so would i put rp in a 15yr old gas engine with 150k miles that has been running valvoline(ie) all its life? no. chances are the seals would go to leaking.
