A/C help....
Old Apr 22, 2008 | 11:36 AM
ThunderZ28's Avatar
Default A/C help....
Anybody know what would cause the AC to get stuck on Defrost/floor vents...
I went to turn it on the other day, and no matter what I set the AC too. the defrost/legs only work..
so if I set it on MAX A/C it blows it out the defrost vents, and the leg vents..
any help here??????
ThunderZ28's Avatar
oh and it's not the switch, I already checked that out..
Old Apr 22, 2008 | 11:41 AM
jlrz28's Avatar
10 Second Fun Car
There is a T connection underneath the hood towards the back of the engine on the passenger side that was broke one time and that was the fix for me. Its small vacuum hoses that come together.
Old Apr 22, 2008 | 12:37 PM
ThunderZ28's Avatar
hmmm that might explain it then...
I just installed some LT's
Old Apr 22, 2008 | 12:52 PM
BadCompany VP WS6's Avatar
Check the back of your intake, there is a vacuum hose that can come disconnected. This happened to my buddy in his SS and that was the fix. Hope that works for you.
Old Apr 22, 2008 | 12:55 PM
TheBlurLS1's Avatar
That's what she said...
The hose is maybe 1/8". The nipple that the hose attaches to is on the opposite side as the nipple for the brake booster hose. I'd say you can't miss it, but it's quite easy to.
After the 1/8" nipple, some year models have a Tee. One side goes to a vacuum canister by the passenger side foglight, then to the A/C box. The other side goes to the AIR solenoid (looks like a spaceship). If you deleted the AIR system when you did the headers, you can just delete the Tee and plug the hose that runs toward the PCM/AC box directly into the manifold.
Old Apr 22, 2008 | 06:12 PM
ThunderZ28's Avatar
found it..
It was the t next to the PCM..
Broke off...
It's back on there for now, but I will need to go buy a new one..
thanks again
Daniel
