Anyone want to finish the plug/wire change?
Remove the AIR pipe and the coil packs above the back 2 plugs since you have a 98. Rest your knees on the battery and lean in and try it from the top. Going in from the bottom is way too difficult, looks like you have stock manifolds like me, so do not try from the bottom as many others say. What worked for me was a 1" extension on a standard wrench with the spark plug socket which I bought at Sears. Takes some time but it will be cake once your finish the 1st change!
Are you a big guy or something. I just did mine today from the top, it took about 45 minutes. I take the coils off the pass side and reach it all from the top. The bottom might be easier but the top is not that bad.
u should have deleted the egr and air by now
remove coil packs and egr tubes, a 3/4 wrench with a spark plug socket is all i use to remove the plugs, lt, stock manifolds, st, it dont matter
use a 1 3/8 freeze plug to the egr hole in the intake manifold and delete the egr system while ur at it.
ive never had to go under and remove the starter to get to number 8
it took me a bout 5 min. to figure out to take off the coil brackets, first time out chaging plugs
