Intake Bolt Broken - Any Help?
Old May 18, 2008 | 10:50 AM
E V I L's Avatar
Default Intake Bolt Broken - Any Help?
I attempted to remove my LS6 intake yesterday and somehow when removing the front right bolt it snapped in 2 (the threaded part) and is stuck inside my motor. Without actually removing the intake because I put the TB and lid back on and stopped when this happened. Anyone have any tools to remove an intake bolt that is inside the block? Or someone that can point me into the direction in getting it out?
I am located in Houston and will pay if someone can help me out! Thanks
Old May 20, 2008 | 11:24 PM
E V I L's Avatar
TTT any ideas?
Old May 20, 2008 | 11:40 PM
newton's Avatar
I guess if the bolt is not too far back in the engine, you can try drilling it out.
Old May 21, 2008 | 02:11 AM
stoverz28's Avatar
I did this once doing H/C on my Z. I thought all the bolts went into the heads not the block, could be wrong.
What i did was took a piece of a hack saw blade to file a slot into the top of the bolt. I then screwed it out with a small flat head.
Old May 21, 2008 | 08:52 AM
herronz28's Avatar
I saw a guy spot weld a thin piece of metal onto the top of a bolt like that. He spot welded, then bent the rod and turned it out by hand. Pretty gruff guy, but he had serious skills to weld inside a hole like that. I wouldn't suggest just anyone doing that..........
Old May 21, 2008 | 09:06 AM
BigPapi61's Avatar
Another option is using an EZ Out bolt extractor. Drill a small pilot hole, screw in the ez out, and then remove the broken bolt. Any auto parts store, Sears, etc should have these.
Old May 21, 2008 | 12:32 PM
Tootall's Avatar
give me a call . . . too much to type
Old May 21, 2008 | 12:39 PM
AGRV8D's Avatar
too ez to get a tap and die or ez out and back that sucker out
Old May 22, 2008 | 07:30 PM
E V I L's Avatar
Anyone in Houston able to come by the Heights to take a look at my car tonight? I have the intake off but no way of getting the bolt out. My cell is 832-492-4331. Please call if you can come help for some cash. Thanks
