Little computer help
Old Jul 23, 2008 | 09:31 PM
Dex's Avatar
Dex
Default Little computer help
Ok this morning i went to get on the computer and it wouldn't wake up from sleep mode just a black screen. No biggie turned it off and back on and it took 10 min to load made it to my background screen and i got a blue screen saying it had a fatal error or something. And its done the same thing a couple times i have tried it. What died? I was told it was the hard drive but i don't know how much he knows about computers. Before i spend $60 on a hard drive i'd like to know what you guys think it could be.
Its a laptop toshiba a-75 it it matters and its 4 years old.
Thanks
It also gave me a reason to buy a new desktop
Old Jul 23, 2008 | 09:33 PM
chupr0kabra's Avatar
Blue Screen of Death.
See if you can get the code off of that screen. Probably something like STOP 0X000000. That will help us figure out what is fried.
-Mike
Old Jul 23, 2008 | 09:40 PM
cruzc5frc's Avatar
ick.. ya start lookin at desktops.. good rule of thumb is plan on replacing laptops or every 3-4 years anyways.. the newer ones are so much faster, bigger HD, more memory, and way more efficient battery-wise.. ::
Old Jul 23, 2008 | 10:14 PM
Griml[]ck
Guest
Posts: n/a
It has worked for me and maybe it has nothing to do with the problem, but I've totally reformatted the HD and re-installed windows (assumption of os). But like the others said, it might be something else, try it.
Old Jul 23, 2008 | 10:28 PM
What a Rush's Avatar
From: Putting my feet in your couch, cause thats how im living
Dude quit downloading gigs worth of **** every night and give yourself a break. Maybe your comp is trying to tell you something?
hope that helps
Old Jul 23, 2008 | 10:44 PM
Griml[]ck
Guest
Posts: n/a
Just what kind of crap are you giving him from your server?
Old Jul 23, 2008 | 11:06 PM
Dex's Avatar
Dex
i finally booted and it blue screened STOP: 0x000000f4(0x00000003, 0x82ac0248, 0x82ac03bc, 0x80604528)
almost fully boot it was trying to do the startup programs and died it also wouldnt attemp to boot unless i had it plugged in.
Old Jul 23, 2008 | 11:09 PM
Dex's Avatar
Dex
Just bought a desktop
I wouldnt even attempt to reformat it the screen just stayed black i also have to run and external cd drive factory took a crap
hahaha
Old Jul 23, 2008 | 11:13 PM
newton's Avatar
Your computer is going to blow up.
DANGER TO MANIFOLD!!!
Old Jul 23, 2008 | 11:14 PM
brad8266's Avatar
Thanks
I am assuming you are runnign windows XP.
If you can get the computer to stay on a few minutes go to:
Start button ---> My Computer ---> Right Click on Local Drive C ---> Properties ---> Tools tab ---> Error checking button ---> Check both boxes and click start. The computer should ask you to reboot to check the disk, let it do that and if all is good with the disk then you should likely replace the system memory.
Another way to check the disk out even if it wont boot is to use your XP or toshiba recovery CD and pop it in and boot to it, the XP disc has a repair area on it that will attempt to repair the drive and the toshiba disc should too.
I am going to take an educated guess (I own a computer repair and networking business) and say that the memory is jacked up. If you get the blue screen of death it is usually bad memory, especially in laptops. I see this all the time.
Good luck.
Old Jul 23, 2008 | 11:26 PM
Dex's Avatar
Dex
just got a new error 0x000000f4(0x00000003, 0x828fc488, -x828fc5fc, 0x80604528)
it wouldnt even boot
Old Jul 23, 2008 | 11:33 PM
brad8266's Avatar
You should try new memory, it is PC2700 type and a 1GB stick runs about ~70 new. Or you can go with the cheaper PC2100 style.
That computer has one memory slot.
Old Jul 23, 2008 | 11:42 PM
Dex's Avatar
Dex
Yea it has 256 intergated memory and one stick of 512 now i hope i can find my old memory and try it. If i cant find it i'll go to the store and buy some worst case it doesnt work and i'll return it
thanks
Old Jul 24, 2008 | 12:11 AM
leeluther252's Avatar
I agree with the memory issue.. Ive seen it many times. Especially if you have added memory.
Old Jul 24, 2008 | 09:47 AM
Blackfly's Avatar
Good luck.
I agree...I build/have built a bunch of "high end" systems.
