locked my keys inside my car
Oreillys sells slim jims for 15 bucks in the package. Ive pissed off a lot of people by opening them in less than 10 seconds. If your in the middle of nowhere and you have fixed antenna you can use it as well.
I used the antenna from my buddies Mustang when I locked my keys in the car.
Pulled the window back, stuck my arm in up to the elbow (wouldn't go in any further), handed the antenna threw the window to my other hand and slid the lock forward.
I don't think you're supposed to be able to hit the unlock button when the alarm is on, which is why you have to slide the lock itself forward.
You can do it, just gotta keep at it.
UPDATE: ok i got a yard stick wedge through the weather stripping and when i press the unlock butten it doesnt do anything but when i push the lock butten i can hear it locking. Iv done this on both sides of the car and it does the samething. So if anyone has any suggestions plz tell me
My brother locked his keys in his trans am and he found out that you cant press the power lock with a coat hanger cause it will just lock automatically back. And the coat hanger chipped his window. So be careful!
#37
Last time i locked my keys in the car. I got a fishing pole and stuck it through my driver side window and jammed it into the passenger side lock and opened it up the 1st try.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
So next for you guys who lock their keys in. Try using a fishing pole. It works better than a coat hanger...
#39
i just posted to help him out, some people dont know about it though, id rather know than not know, atleast you will know how they got into ur car without breaking anything. if they wanna take it down they car, i dont care lol.
#40
LS1TECH & Trucks Sponsor
The BCM goes to "sleep" after 5 minutes and you can not use the electric unlock button or the truck release button to open anything until you "wake up" the BC< with the key in the ignition, opening the door, or the keyless entry. It's so that random people can't stick something in your window to hit the button and open it.
I recommend against pulling the glass out to unlock the car, it's hard on the internal door parts and you can damage the track and the fiberglass mounting points by doing so. Some people do it without causing any damage, I know that, but many people damage their door and/or window track as well. I have even seen someone knock a huge chunk out of the top of the door that way.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
