Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
getting ready to do a cam swap......tools????
Old Oct 12, 2008 | 11:02 AM
neil1b's Avatar
Default getting ready to do a cam swap......tools????
Guys........what tools are going to be needed besides the stadards............ ramps vs jack stands, speacialty tools etc.
Old Oct 12, 2008 | 11:38 AM
01ssreda4's Avatar
i did mine on rhino ramps. i got the kent moore flywheel tool to hold the motor while tightening and untightening the crank pulley. i also got tims valve spring tool, and hawks balancer installer. all three work like a dream and made the cam install super smooth. low 30s for the spring tool on here new, mid 50s for the installer tool on here new and 70 on ebay for the kent moore tool new.
Old Oct 12, 2008 | 06:46 PM
Hilton's Avatar
Tough Mudder
That hawks balancer installer is worth it's weight in gold.
There are a bunch of threads on cam installs. It's not that hard to do.
Old Oct 15, 2008 | 02:52 AM
azceta's Avatar
Somebody has a tool for that! I have been using a deadblow hammer for ever thank god someone has a installer fo it now.
Old Oct 16, 2008 | 08:57 PM
Damian's Avatar
LSX Mechanic
-You will also need a disconnect tool for the fuel line
-RED loctite
-Brand new crank bolt
-Good/accurate TQ wrench
-Some 1/4-5/16 dowels to shove in the motor to hold the lifters up
-Pre-assembly engine lube (I always put this on cams before putting them back in)
-Some high temp RTV to put in the corners of the timing cover upon reinstalling
-All TQ specs handy
-Common sense
Old Oct 17, 2008 | 07:06 PM
dogger's Avatar
-RED loctite
-All TQ specs handy
-Common sense
I guess means I can't swap out my cam this winter.
Old Oct 17, 2008 | 07:25 PM
Hilton's Avatar
Tough Mudder
Nah, with the stuff mentioned about and "lefty loosey, righty tighty" you can get it done.
Old Oct 17, 2008 | 10:11 PM
01ssreda4's Avatar
yeah hilton you're a pretty good cam installer after you have a few beers. i got this guy to lay in a deep puddle of water on the dirt to hook hoses up from the bottom. swell guy that hilton....
