powder coating gun/setup?
I would rather avoid the "el chepo" guns that I see around online ($20-$50 kits) and instead get something that will LAST, yet avoid needless "bells and whistles". To set the "quality level", all my air tools are Ingersoll and Chicago Pneumatic, 220Volt/7.5HP/35CFM@145psi compressor, and 220Volt MIG and TIG.
As I said, I'm not doing business stuff but rather this is to take the place of spray painting small parts that would otherwise have to go to a local powder coater. For anything "big and special" I'll take to a professional.
So what should I look into? I know some guys on here do home coating (manifolds/valve covers/calipers/etc), what do they/you guys use?
For my small stuff that you mention. I use the POR stuff. Easier for a newbie like me to brush on.
I got a cheap elect oven from a buddy that got a new one. It just seems easier to me & the finish is excellent.
I coated a set of exhaust manifolds ~8-10 years ago & they still look great.
Whatever you do DON"T put powdercoated items in your kitchen oven. There are some nasty chemicals released in the curing process. Trust me, I work for a supplier of powdercoating.
http://forum.eastwoodco.com/forumdisplay.php?f=9
That being said, here are my .02:
I use the Harbor Freight(HF) gun, it is low cost (~$50-60), and if it breaks I just exchange for another. Many guys start with this gun, and later keep it as a permanent gun for a popular color (like clearcoating, or black).
The newer guns out such as the sBay gun, and the more consumer oriented stuff from Columbia Coatings(CC), and Powder by the pound (PBTP) are pretty similar and a good step up from the HF stuff. Here is a good thread on some of these newer options:
http://forum.eastwoodco.com/showthread.php?t=8523
FWIW I see a lot of guys have had problems with the eastwood pro gun, I have never had any experience with it though.
For powder for a small user like me PBTP has good prices on powder, and other supplies (high temp tape, plugs, caps, etc...)
Your real limitation is the size of the oven you can cure stuff in. So get the largest you can because soon you will be looking to do larger stuff.
Good luck!
Powder Coating Beginners Blog
little site I've been putting together over a few months with some good details and all with getting started.
Powder Coating Guns --- direct link on an article I wrote breaking down the various guns, most of which I've used.
Powder Coating Oven --- a large capacity oven I'm going to build for our shop, figuring in materials and everything I'm under $2,000 for an oven large enough to do fenders, bike frames, solid rears and plenty of other items... and I will be posting plans for this build too, though I don't have a ton on it yet
Got any further questions, just lemme know
Anyways, Id definitely look at Eastwood's kits. If you really want to get technical, Id look into Caswell. I believe they have an adjustable voltage gun which comes in REAL handy when you're doing 2-stage jobs, or trying to coat over chrome or anything like that.
