Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Air compressor
Old Nov 27, 2008 | 04:43 PM
94'BLKBRD's Avatar
Default Air compressor
What do you guys think about this air compressor? Big enough for Automotive use?
http://www.northerntool.com/webapp/w...9573_200359573
Old Nov 27, 2008 | 04:51 PM
94'BLKBRD's Avatar
or this one
http://www.harborfreight.com/cpi/cta...emnumber=93271
Old Nov 27, 2008 | 09:54 PM
vaughn4's Avatar
i would stay away from those.. look at the cfm ratings, those would never keep up with a die grinder, air saw, paint gun.
look up curtis compressors.. they are high but worth every dollar.
http://www.curtistoledo.com/home/
Old Nov 28, 2008 | 09:54 AM
Camaroholic's Avatar
Really, you need to define "Automotive".
Impact tools, inflating tires, air ratchet, blow gun, etc... for light usage (one guy wrenching on a car), they'd be fine. I ran a low end compressor for years until I outgrew it (painting, DA sanding, etc - those little ones won't keep up). The low end one did fine for me, and now I have my 'big' one, and sold the little one.
They are likely the exact same compressor. Wait for it to go on sale at HF, and then use a 15% off coupon to get an even better discount. Patience pays off when shopping at HF. I'd bet it'd go on sale for $179 at HF, and then with 15% off from there, you'd be looking at about $150. Not bad.
I like oil lubricated compressors, not oilless (those are oil lubricated). That part is good.
Old Nov 28, 2008 | 12:18 PM
94'BLKBRD's Avatar
That's what I'll be doing
Old Nov 28, 2008 | 05:51 PM
Schnell's Avatar
HF sells the exact same one as the northern tool one your looking at. The HF one you posted is 220v. I have the 120V HF model. It's 5 years old and I use it a good deal. For the money it was well worth it.
Old Dec 3, 2008 | 11:36 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
You could even look at the craftsman compressors. I've used a 30 gallon upright for 6 or 7 years now and it's been fine. I stepped up to a 60 gallon, 2 stage because I needed a quieter setup and wanted the bigger storage that the 60 gallon offers.
Old Dec 7, 2008 | 01:00 PM
spanky1's Avatar
keep your eyes on craigslist around you, Bought my 7.5 80 gal Snap-On with 38hrs on it for 900.00 its worth a try.
Old Dec 7, 2008 | 02:49 PM
94'BLKBRD's Avatar
Is this a good compressor/good deal? It's a Porter Cable 7hp 60 gallon
http://inlandempire.craigslist.org/tls/941072180.html
Old Dec 9, 2008 | 11:51 AM
spanky1's Avatar
i think that compressor new is around 800.00 but dont hold me to it. That is plenty big and beat him up to 450 and i think your good looks clean
Old Dec 10, 2008 | 12:03 PM
UNDER PRESSURE MOD
Looking at that compressor, it looks like a good deal.
I just picked up a 2-stage, 60 gallon Craftsman from the mid 90s that was in excellant condition. It needed the head retorqued, and the manifold needed to have the threads re-sealed, but other than that, it was perfect. It will cycle from 125psi up to 175psi in about 2 minutes, and even using a grinder, it will still cycle on/off while working unlike my old 30 gallon craftsman that couldn't maintain the 90psi while I was working. Granted, that only delivered ~6cfm at 90psi, and my new one will deliver 12cfm at 100psi.
Old Dec 10, 2008 | 06:46 PM
01ssreda4's Avatar
i have the 220V version of the one pictures above and it is only good for light duty plus its noisy. if you got just a little more change to spend check this one out. very reasonable for the cfm.
http://www.harborfreight.com/cpi/cta...emnumber=92504
