Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Cleaning up rusty pliers?
Old Apr 26, 2009 | 10:52 AM
MustangEater82's Avatar
Default Cleaning up rusty pliers?
Anytips on cleaning them up? throw them on a wire wheel, anything to protect them afterwards... if you saw my other thread, scored a couple pair of Channel Locks, all work fine just look rough, wouldn't mind cleaning them up a bit though.
Old Apr 26, 2009 | 06:56 PM
VETTEX2's Avatar
Wd-40
Old Apr 26, 2009 | 11:54 PM
Gordon0652's Avatar
PD Blaster
Old Apr 27, 2009 | 03:51 AM
deuce_454's Avatar
put them in a bucket of coke... rinse the next day and apply wd-40 and exercise them...
Old Apr 27, 2009 | 07:23 PM
Silverback's Avatar
the cleaner you get them, the worse and faster they'll rust/get messed up next time. I'd soak them in some pennetrant (there are actually specific ones for protecting tools), get them working smoothly and consider the finish a "patina."
Old Apr 30, 2009 | 10:20 AM
Black Sunshine/ 00SS's Avatar
lol, I was just about to say that..
Old Apr 30, 2009 | 10:37 AM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
I have done this before..worked pretty good.
Old Apr 30, 2009 | 04:55 PM
01ssreda4's Avatar
clean them of course but dont leave em bare. gotta protect them with something.
Old Apr 30, 2009 | 05:47 PM
JTM's Avatar
JTM
Bead blasting cabinet will do an excellent job on removing all rust.
Old Apr 30, 2009 | 07:53 PM
rideon1200's Avatar
Spray them down with WD40 and work them. Then use a old rag to wipe off and realize they are tools. You could proably buy a pack for $25. at HD.
Old May 4, 2009 | 05:05 PM
Phil99vette's Avatar
7 Second Club
Pool PH up + a battery charger.
Old May 9, 2009 | 09:41 AM
sroach20's Avatar
i use linseed oil on the tools and they do not rust.
Old May 10, 2009 | 12:00 AM
LCplmarine98's Avatar
once you clean em spray with silicon lube and leave it on as a protectant and it shouldnt attract dirt.
Old Jun 4, 2009 | 09:52 AM
merim123's Avatar
this is the only thing i use, i have done this many times. i use rebar, my battery charger and oxyclean. everything comes out great, i'll takes some pics of the upper control arms i did this way...
