Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Best Valvespring Compressing tool?
Old May 1, 2009 | 03:57 AM
BAMF's Avatar
Default Best Valvespring Compressing tool?
I'm going to have to buy a new one because the one I have it to big to work under the cowl of these 4th gens....so which one are you guys using??? which works the best??? I've seen one that you turn a nut down to compress the spring and another that you use a ratchet to turn and compress the spring...which is better?
Old May 1, 2009 | 04:47 AM
vettenuts's Avatar
The Crane tool, also so by Vinci High Performance is the best one out there. Does two springs at once and is an exact fit so doing the back cylinders is not as hard.
Old May 1, 2009 | 07:44 AM
gillbot's Avatar
I use the crane tool myself, makes it much easier.
Old May 1, 2009 | 08:24 AM
MBC Racing's Avatar
Crane tool. Worked awsome. Especially on the back cylinders!! Used it on my GTO and Z.
Old May 1, 2009 | 09:01 AM
mebuildit's Avatar
I've always used Buxton Engieerings spring checkers. They cost more and are a piece of art. Here is the link: http://www.buxtonengineering.com/on_...ing_tester.php
Old May 1, 2009 | 09:08 AM
99_SS_LS1's Avatar
I've used "Tim's tool" for two swaps. Works great, and is inexpensive.
Old May 1, 2009 | 09:36 AM
bigboykilroy's Avatar
+1 for the crane tool awsome !!!
Old May 1, 2009 | 09:51 AM
yomama's Avatar
+10000 for the crane , its the ****
Old May 1, 2009 | 11:02 AM
vettenuts's Avatar
Whatever you do, don't get one of the cheap ones with the two claws and the **** on the top. It will scratch the spring surface and could cause spring failure down the road on a high performance surface treated valve spring.
Old May 1, 2009 | 11:19 AM
04gtoBMXracer's Avatar
Crane cams tool worked great for me.
Old May 7, 2009 | 02:16 PM
Chrome355z's Avatar
Where can you buy the crane tool now?
I can't seem to find the LSX one on Summit anymore...
Old May 8, 2009 | 08:55 PM
gillbot's Avatar
i got mine from jegs
Old May 9, 2009 | 09:16 AM
01ssreda4's Avatar
i agree.........
Old May 14, 2009 | 10:39 PM
Damian's Avatar
LSX Mechanic
x 1 million
Old May 15, 2009 | 08:28 AM
01formula6's Avatar
I'll throw in another vote for the Crane tool. It's an absolute breeze to swap springs. I got mine from SDPC ------>
Old May 16, 2009 | 10:04 AM
budhayes3's Avatar
PT's Slowest Truck
Crane tool hands down
Old May 20, 2009 | 01:11 PM
BAMF's Avatar
I'm having a hard time finding the crane tool anywhere, where did you guys buy yours? right from crane?
Old May 22, 2009 | 05:29 PM
1sick'98WS6's Avatar
I had a hard time finding a crane tool in stock. I ended up paying a little extra and buying it from jegs
Old May 22, 2009 | 06:01 PM
spaz1's Avatar
just get tims tool it worked mint for me. His hose is a bit hard thow I got it but ended up using the hose off my compression tester.
Old May 22, 2009 | 06:41 PM
99blancoSS's Avatar
SpeedInc has revived this tool
