Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
My first welder....
Old May 2, 2009 | 09:15 PM
jetlag's Avatar
Default My first welder....
So... new to this whole welding thing. I've never even touched a welder before but I have big plans for my 1973 Toyota Hilux (truck).
The Toyota will eventually get a V8 swapped in along with a rearend from a Mustang. Big plans in my head, so it's time to get some practice!
The welder I will be using is a Hobart Handler 187... it was a good deal and hopefully it can handle all I'll need to do.
I just tried out my first weld. It was raining today so I couldn't find any scrap metal...All I had was two exhaust turndowns that I "tried" to weld together. They are stuck, but its the ugliest weld I've ever seen..haha Right now I don't have any gas, so it's just running on fluxcore.
Old May 3, 2009 | 01:28 AM
Gordon0652's Avatar
Thats why the weld does not look good at all.
If your doing mild steel you would want to 75/25% gas. That will make it look a whole lot better!
If you need info on gas for welding, do a quick search in "tools" because there was a very good thread posted about types of gases.
Hobart are awesome welders i have two myself the 140 & tigmate. I upgraded the 140 so now it's collecting dust...
Goodluck with the welding and project!
KeNNy
Old May 7, 2009 | 08:30 AM
Old Geezer's Avatar
Adding to the problem, could be the coating on the pipes, u were welding on.[Assuming they are not stainless].
The fumes from welding on galvanized coated materials gives off a deadly gas..Use care.
Old May 7, 2009 | 09:22 AM
01ssreda4's Avatar
^^^well if its exhaust pipe it would be aluminized coating.
Old May 7, 2009 | 09:34 AM
Old Geezer's Avatar
Default If so..
it still will not weld well, especially w/ flux wire....
Old May 7, 2009 | 09:45 AM
jimmyblue's Avatar
Moderator
I'd practice and try out various voltages and wire
speeds before writing off flux-cored. I've gotten
some decent looking welds off my cheapo wire box
but there is a definite "sweet spot" to it (even on
clean metal). When you find the magic combo be
sure to make a note.
Old May 7, 2009 | 11:51 AM
01ssreda4's Avatar
i have been a welder for 5 years and yes you can make exhaust welds look good with flux core. its not that easy though.
Old May 7, 2009 | 11:34 PM
Gordon0652's Avatar
Thats for sure!
