Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
dremel polishing compound
Old Jun 4, 2009 | 10:53 PM
wtomlinson's Avatar
Default dremel polishing compound
does anyone know how to use this stuff?
i bought a little kit the other day that came with a bunch of polishing wheels and whatnot, and a little tub of polishing compound (reddish looking clay). how are you supposed to use this stuff to polish?
Old Jun 5, 2009 | 10:26 PM
wtomlinson's Avatar
someone's gotta know
Old Jun 6, 2009 | 12:43 AM
01ssreda4's Avatar
i never opening mine out of the little package
Old Jun 6, 2009 | 12:12 PM
wtomlinson's Avatar
i guess i could play around with it later with different felt bits.
Old Jun 8, 2009 | 09:00 AM
jmd's Avatar
jmd
Play with it. Don't overspeed things if you're doing plastic. Alum. should be easy.
Old Jun 8, 2009 | 09:37 AM
wtomlinson's Avatar
well should i put some of the paste on the cotton wheel, rub it in, then start dremeling?
or, put the paste on whatever i'm going to dremel, take a clean wheel and start?
Old Jun 8, 2009 | 11:21 AM
01350ss's Avatar
use mid level speed. as the dremel is spinning with whatever wheel you are using, lay the spinning wheel over the red rouge (the clay bar) let the wheel melt the rouge. As the bar melts, it will feed into the cotton wheel. Now take the dremel and apply the spinning wheel to whatever your working on. While using the wheel on the piece, get the residue that is left on the piece to turn dark grey to almost black. You do this by continued passes of the wheel over the area. You will need to re-apply the red rouge to the wheel in the same manner I described above. Use slow even passes over the entire work area. Once you have completed this step. Start over with another wheel and the white rouge. Do the same thing.
Old Jun 8, 2009 | 01:42 PM
wtomlinson's Avatar
all it came with was red.
Old Jun 12, 2009 | 09:12 AM
01350ss's Avatar
so than just use the red. after that buff it off with microfiber and maybe some polishing paste like mothers
Old Jun 12, 2009 | 08:01 PM
wtomlinson's Avatar
do you use metal polish like any other polish? let it dry and buff it off?
Old Jun 15, 2009 | 10:16 AM
01350ss's Avatar
its already a dry paste no need to wait
Old Jun 15, 2009 | 10:51 AM
bumpin_records's Avatar
take pictures and show us how it look when your done.
Old Jun 15, 2009 | 01:49 PM
wtomlinson's Avatar
will do. thanks for the input guys.
