Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Structural Integrity question: trunk
Old Sep 17, 2009 | 07:24 PM
hawk584's Avatar
Default Structural Integrity question: trunk
the " trunk "/ where the T-tops go in a 4th Gen F-body, is it a structural strong point? i was toying with the thought of cutting 6" out off the trunk or making it somewhat level with the rear deck lid to create an open space to tuck the rear-mount turbo up and out of the way and further away from the ground
Old Sep 20, 2009 | 08:09 AM
01ssreda4's Avatar
Any of the metal thats above or around the rear suspension components is in fact structural.
Old Sep 20, 2009 | 01:10 PM
3rdgen92maro's Avatar
Check in the drag racing section. There are alot of people who cut the "T-Top hump" out and just weld in some sheet metal to make the trunk flat like your saying. I don't see how it would loose any integrity as long as you welded new sheet metal in.
https://ls1tech.com/forums/drag-raci...runk-area.html
Old Sep 21, 2009 | 03:40 PM
hawk584's Avatar
thank you 3rdgen
