Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
TPMS tool?
Old Nov 3, 2009 | 06:51 PM
waltsfastz's Avatar
Default TPMS tool?
as a shop owner I am at the point Im going to have to look into one of these, We have doged the bullet a few times but really needed it other times as well. Anyone know of a decent one worth the$$$. I have connections to get almost any brand at cost. any suggestions?
Old Nov 12, 2009 | 07:07 PM
livefast1's Avatar
they taught us in more than enough seminars that all you need is a magnet tray. send the car into reset/learn mode, hold the tray next to the sensor until the horn beeps for each tire.
Old Nov 12, 2009 | 08:05 PM
waltsfastz's Avatar
Hmmm, Ill try that. Does it work for replacement sensors as well?
Old Nov 17, 2009 | 08:39 PM
livefast1's Avatar
should work on them all
Old Nov 18, 2009 | 01:33 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
The Bartec Wheelrite 400 is what you need for your shop. The NAPA part number for the tool kit is NTH 92-1520. About ~$1300 here in Alaska. Plugs into the OBD port to program new sensors, very easy to learn and use.
Old Nov 18, 2009 | 02:04 PM
waltsfastz's Avatar
Ill check into it. And Ill try the Magnet Meathod.
thanks a lot fellas
Old Nov 18, 2009 | 03:23 PM
luigiandme's Avatar
The magnet, i know is for C5 vettes. But on most Gm vehicles with TPMS you can enter the learn mode and starting from LF going clockwise ending at LR, you can release air or add air to the tire and it will honk once recognized. ie. Trailblazer... Key On, Pull parking brake lever, cycle headlights from on to off/auto three times within 3 seconds and horn will honk once done, the bcm is now in tpm relearn mode. Starting with LF, add or remove air for about 5 seconds. Pause and wait for a honk, if no honk, continue to remove or add air to the same tire. Then continue on to the RF then RR then ending in the LR and usually the vehicle will Honk Twice, notifying you that it is Done relearning and is no longer in the relearn mode. Cycle the key once and start the car.
Old Nov 18, 2009 | 03:33 PM
luigiandme's Avatar
Or buy the J tool... J-46079 Search Ebay for that bad boy!
Mario.
