Electric garage heaters?
Are they any good? I'm looking at a 10,000 watt one, that hangs from the roof.. Is this going to be enough to heat a 24 x 34 insulated and drywalled garage?
It Won't Work
Electric heaters are way too expensive to operate, especially in Michigan. A 10kw heater won't even take the chill off a building that size in the winter. I had a 10kw unit in a 1.5 car garage and it took about 2 hours to warm the place up. The electric bill was outrageous.
Do you have gas or propane available? I have several good used furnaces if you are looking for one. What part of Michigan are you in?
Wood an pellet stoves are nice but the insurance company will not cover your lose if there was a fire.
http://www.northerntool.com/webapp/w...+770345+155629
Not sure if this link will work. Great heaters for the price I have a 45K in my 22 x 32 garage
build you own used oil burning heater... have used one for years to heat a 40x60 shop... i live in nebraska and we have cold winters.
the best part is that they are cheap... almost free to make... and you gan get used oil for free!
a 55gal drum will last for 1-2 weeks heating 24/7!!!!
well here is the same general idea as what mine is....
http://www.youtube.com/watch?v=CJYMyMHHB5U
this will be very helpull to you also...
http://www.youtube.com/watch?v=8BUm2BK3-qw
mine had a fan that blows lightly through some pipes that are put all the way through the barrells and a smoke vent to the outside...
I no longer live at that house...
I will be building a new one for my new shop (i might be moving to a new house with a shop again!) I miss my shop lol.
i love waste oil furnaces, im probably going to rig one up when i get my own garage.
id get a propane unit heater if you didnt wanna deal with oil. dont bother with electric, slow recovery and it'll kill your wallet to get that little bit of heat. the only time electric is acceptable to me is if you have free electricity or live in a climate that doesnt get cold.
These heaters are the cats ***. This will bring my garage from 0 degrees F. up to 65 degrees F. in 30 minutes. They run on propane or natural gas. I can heat it for two months on $65. I leave it at 40 degrees when im not in the garage. Just cold enough so the beer stays cold.
wood if you can i live in wisconsin and have a old house furnace,and it works well. pellet stoves i had one and a biomass furnace which both suckes wouln't autostart get plugged auger problems overtemp computers melt ahhhh. switch insurance companies if they won't let you have an explosed flame heater the best woula been infloor heat! i might saw out the concrete in there now and repour this summer with a heating ciols in it and try using a small water heater with it
i got a 55k kerosene torpedo, it works on my 24x30 garage with NO insulation. i usually start it about 20 minutes before I go out there and its always warm enough in the garage for me to work in just a tshirt and jeans. even last week when it was 10 degrees out. I run it on diesel i buy from the local gas station. 5 gallons will usually last me about 10-12 hours of run time. bought it for $100 bucks off craigslist and it came with a thermostat too. on the weekends i usually fill it up on friday afternoon, set it to 40 degrees and leave it, then just turn it up when im in there working on the car. usually lasts all thru sunday afternoon
torpedo for sure.. a buddy of mine has one of the big ones...and i mean big ones 6feet long and the opening is the size of a hub cap or if we turn it on in the shop(3 bays broken window.and its like 65 years old..) nd withing 10 min it goes from 50 ish to 95 or more and then u can shut it off for a couple hours...got to love that thing
x2
