Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Is there an Air Compresor brand to AVOID?
Old Jan 16, 2004 | 07:57 AM
Reckless's Avatar
Super Moderator
Originally Posted by Ru2slo_99
A friend of mine that owns a body shop said he goes to Sams Club and buys Black Max air compressors. He said they are tough and only about $600.
I checked Sam's but all they had was a small one, and a really huge one!
Old Jan 22, 2004 | 02:08 PM
Steve98Z's Avatar
Default compressor
Go with an Ingersoll Rand...........
Old Feb 27, 2004 | 10:42 PM
VETTEX2's Avatar
Make sure it has a steel crank......some have aluminum cranks.....they are junk.....
Old Feb 29, 2004 | 10:17 PM
Dueledaily's Avatar
Default Craftsman SuX!!
Mine broke..it fills up with air past its capasity load and them blows the safty valve. Its 2 years old.....new part is 120 to fix. BS!!!!!
Originally Posted by Reckless
Going to finally get a nice compressor in the next few weeks. Good deals at Harbor Freight on Campbell Hausfield and others around also. Are there any brands to avoid?
Looking for about 70gal/7hp with oil and 230v.
Old Mar 5, 2004 | 11:28 AM
kickassT/A's Avatar
i have an ingersal rand 60 gallon 2 stage. no porblems at all, always air when i need it, but it's loud and expensive. i think it was around $900 3 years ago.
Old Mar 5, 2004 | 08:13 PM
PlainwhiteZ28's Avatar
welllllllll
our husky just took a ****..........4th time I have turned it on.
blew a rod or something blew a whole in the plastic housing around the pump.
Taking it back to home depot with a few choice words.
Old Mar 5, 2004 | 10:50 PM
Ackattack1's Avatar
I found somewhere that Husky is made by the same brand as CH, so that kinda explains why the price is essentially the same.
I got a 60 gal. husky in August and have no problems with it. Sprayed in a bedliner in my truck and did quite a bit of grinding with it.
Old Mar 6, 2004 | 11:25 PM
TripleBlackRamAirT/A's Avatar
7.5 HP 80 gallon Ingersoll-Rand 2 stage compressor. This thing will NEVER run out of air on you. I've had it for about two years now and I love it. Its really quiet and never skips a beat. Presure switch is set to turn on at 160psi and off at 180psi. I keep the line pressure at about 110psi so that when under full load the tools are at a constant 95psi. I can work forever with this thing and never have to even think about letting it catch back up.
Old Mar 8, 2004 | 09:48 PM
WEASEL's Avatar
Could be wrong but I believe someone at Lowes told me DeVilbiss makes the compressors for Ingersoll Rand's home consumer products.
