Looking for a MIG NEED ADVICE
im looking at purchasing my first welder. Im not shy about learning new crafts and honestly this is somthing ive always wanted to do.
First and foremost. I plan to use it for exhaust work to start, then after i get more familiar and better with it, i will move onto suspension work. my question is simple, suspension work and possibly roll cages.
if i was looking at a welder, id obviously want a 210/220 unit correct?? just need a model to start looking for and begin to budget accordingly. thanks,
i keep toying with the idea of picking up a 135/140. There are a couple for sale locally, but i dont want to pick something up that wont work when i decide to start my solid rear axle swap. which will more then likely involve welding 1/4 thick steel, and brackets to those plates and to the axle housing. any thoughts.
thanks
kyle
I upgraded from my Miller 135 to a Miller 212 Autoset.
This is an amazing machine. Dial in the metal thickness and it automatically controls wire speed and amperage. Makes a hack like me look like I know what I'm doing.
I know have a Miller diversion maxstar 150 sth that i got at a steal.
Tig at this point is probably not what you should buy, but it's very versatile!
Andy
Mike
On top of it all, if you get a larger machine it will not have to work as hard and will last you much longer.
I see used MIG's going on Craigslist all the time for the same price as new. So don't think you are going to loose a ton of money on buying a bigger machine.
Oh, and read all the reviews you can on the machine you might pick up. Some of them look great on paper but might not suite your needs.
Good luck.
i decided not to buy one yet, until i can budget for a miller 210 or 220. You are right, buy it once, buy it right.
I want to take a few courses but the closest is a 90 mile drive, the college I am currently attending doesn't offer welding.
Once you learn gas welding, TIG comes naturally. Also, it is a good basis for MIG welding, because you will be less apt to make welds that are just filler piled up without good penetration.
I have been quite a few places and hadn't heard advice like that, can't learn if you don't ask.
With any welder, bigger is always better. Its better to have too much than not enough
.I agree with MikeGyver, oxy/ace welding is a great way to learn. While it is a lost art now-a-days it is a good way to get started.
