Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
broken extractor in iron head
Old Oct 25, 2010 | 08:59 PM
tricked94camaro's Avatar
Default broken extractor in iron head
any tips for getting a broken extractor piece out of my iron lt1 heads? this **** is impossible to drill out. it broke off in where the header bolts up on cylinder 8
Old Oct 26, 2010 | 10:23 PM
Daryn's Avatar
Formerly darynC-10/23/10
you will need to use a carbide drill bit to drill it out
Old Oct 27, 2010 | 12:27 AM
tried that... wont do ****
Old Oct 27, 2010 | 02:35 AM
Brief Encounter's Avatar
You are gunna have to take it to a machine shop and have them EDM it out.
"Electric discharge machining (EDM), sometimes colloquially also referred to as spark machining, spark eroding, burning, die sinking or wire erosion,[1] is a manufacturing process whereby a desired shape is obtained using electrical discharges (sparks). Material is removed from the workpiece by a series of rapidly recurring current discharges between two electrodes, separated by a dielectric liquid and subject to an electric voltage."
Old Oct 28, 2010 | 12:40 AM
Daryn's Avatar
CARBIDE? not HSS
Old Oct 28, 2010 | 01:50 PM
gectek's Avatar
Use a Blue Wrench...aka a torch. That is the quickest and easiest way to get it done. Just ask the diesel crowd about it. Blast it out, then clean up the threads after you are done. Ready for a new bolt.
Old Oct 28, 2010 | 10:16 PM
THENASCAR's Avatar
alot of taps, you can shatter depending on your situation, ive had decent luck with a good punch, although the torch is a good alternative as well
Old Oct 28, 2010 | 10:59 PM
twelver12's Avatar
thats the only way ive ever had luck doing that, break it with a punch
Old Nov 5, 2010 | 04:15 PM
XLER8's Avatar
If the extractor is busted off flush with the surface you can lay a nut over it and fill it with weld. Then if you are lucky it will back out with a wrench.
Old Nov 11, 2010 | 11:17 PM
mwg2600's Avatar
That might weld the head material to the extractor. by grounding through it. Ive seen it work on normal bolts though. Try that, then blow the bolt/ extractor out of the hole with the "blue wrench" .
Old Nov 12, 2010 | 12:58 AM
Daryn's Avatar
ever get it fixed?
Old Nov 12, 2010 | 09:00 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
I am not sure that you can weld cast iron to that grade of steel or the steel bolt/nut with just a regular 6011 rod.
Old Nov 13, 2010 | 05:02 AM
Daryn's Avatar
you can weld just about anything to anything with flux cored mig!
Old Nov 13, 2010 | 07:01 PM
Beard's Avatar
false
You can Silicon Bronze weld to cast iron with a little pre-heating. I wouldn't rely on the strength of it though.
The best way to get the extractor out and possibly even the only way is to get it EDM'ed out or to properly use a Carbide bit. Carbide bits will chew through just about anything. The key to carbide is to keep it cool and spin it fast as you can. A 1/4" bit requires about 7,000rpm to cut and not chip the cutter itself. I find that chucking up a 1/4" carbide bit into my 90 degree die grinder will get you hole in just about anything.
