Fluid transfer pump?
Where can I get a pump for transferring fluids? You know, for filling the tranny, the rear end, for draining the PS reservoir, that kinda thing. I've seen em with bulbs or with little bicycle jack lookin things, but now that I need one I can't find one! Argh! I found a cheap one at autozone that doesn't do squat (it was like $5, and doesn't work at all). Checked harbor freight...nothing. Doesn't have to be fancy, just for doing the tasks that I outlined.
Dope
with peristaltic rollers on clear tubing. I found it a
bit flimsy (orange plastic) but it worked for a while.
Also I got a big suction gun, like a 1-liter syringe
which is pretty good and plenty tough (steel
cylinder, O-rings on piston). It will draw or push,
just a manual piston. The Mityvac won't help you
push, only draw fluid.
Dope
Also, should I get the regular Mityvac test kit or the Plus kit? Any useful extras with the Plus kit? Description was vague.
Dope
For P/S fluid or Auto trans fluid I use a suction gun like mentioned by jimmyblue. You can also use it for the rear or manual trans but I prefer my pep boys plastic pump. Less messy.
Here's the Pep-boys pump I have:
Which I found online here
Here's the suction gun:
With a long hose you can stick it down an Auto Transmission dip stick tube and suck out some fluid in case you overfill it
