Started to learn tig welding today.
Weld bead (sideways)
Graded by the instructor
Vertical
Penetration (backside)
Up close (vertical view)
********UPDATE 2/27/11*******
T joint
Looks pretty decent, heat control could be a little better (not that I'm saying I can do better myself, I seem to be able to do things with a MIG most can't but I'm slow to learn with my TIG, I keep thinking a formal class might help...)
if you would have made it all thin like that it would have been 100... he probably just marked it because you varied from one spot to the other. It looks like the amount of weld surface excedes the material thickness by 200% .... its more than good. The Best V8 Stories One Small Block at Time
if you would have made it all thin like that it would have been 100... he probably just marked it because you varied from one spot to the other. It looks like the amount of weld surface excedes the material thickness by 200% .... its more than good.My $.02 from what I'm seeing in the pictures is that in a perfect world all of your weld would look like the spot marked. You have full penetration there, but didn't put any more heat into the weld then you needed to get that full penetration. No big deal for mild steel but it could make a difference for some aluminum, stainless and some alloys that could get brittle and even damaged with excessive heat input.
Silverback, what do you mean brittle? Aluminum and stainless would require less penetration or more?
aluminum and SS don't require any different amounts necessarily, but you have to be more in control of your heat input. Keep in mind, heat input is a function of travel speed too, not just volts/amps. stainless is a little less forgiving than mild steel, and alumuinum is even less forgiving. for example, say you're welding 1/8" steel plate together, you might set your TIG to 160 amps (for example) and hit the pedal wide open and go. With aluminum, you'll be better off setting it upwards of 200 amps and you'll be feathering the pedal the whole way. you'll learn this in your class quite quickly i'm sure.
