Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
What is this damn thing called?
Old Feb 6, 2011 | 11:20 AM
The Bronx Bull's Avatar
Default What is this damn thing called?
I need one of these for a tight space; what is it called? Tried searching: Phillips wrench, phillips key, phillips L-shaped, etc...
Old Feb 6, 2011 | 12:22 PM
Ryphraph's Avatar
Offset screwdriver...
Ryph
Old Feb 6, 2011 | 12:47 PM
Ryph
Old Feb 7, 2011 | 02:51 AM
stimpy's Avatar
one of them goofy screwdrivers I have about 10 of in my tool box with no use for ..
oh a little tip for using one to keep it from popping out of the phillips cross put a little toothpaste like colgate on the tip as it fills it in and the grit prevents it from slipping out , the toothpaste washes off without damage . or you can use real fine valve lapping compound . but it takes solvent to remove it .
Old Feb 7, 2011 | 03:54 PM
Silverback's Avatar
Polishing or rubbing compound works also, at least about as well as anything else... (which is to say that nothing really works great with those things)
Old Feb 8, 2011 | 02:04 PM
silversrtman's Avatar
whats the point of those? I always see them, is it just getting in tight spots? or something else?
Old Feb 8, 2011 | 09:39 PM
stimpy's Avatar
I think the proper name of it is the engineers revenge device . I only had to use one on some moulding on a car a long time ago , like I said I have about 10 of the things in the screwdriver drawer from all the sets I have boughtover the years , wait hold on .. damn I think one is pregnant ...
Old Feb 8, 2011 | 10:18 PM
396D1SS's Avatar
you can buy them at home depot or lowes for a dollar fwiw
Old Feb 13, 2011 | 12:35 AM
axon360's Avatar
I got a set of 3 ratcheting screw drivers off the matco truck for around $25 that work wonders!
