Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
"Just in case tool bag"
Old Jun 16, 2011 | 08:10 PM
CaMaRo67RS355's Avatar
Question "Just in case tool bag"
Trying to put together a tool bag to keep in the car for when something unexpected happens. So im trying to figure out what should be in it. Ive got some stuff but am open to suggestions.
Old Jun 17, 2011 | 01:11 AM
01ssreda4's Avatar
I don't typically carry "tools" but I do carry an extra belt, fix-a-flat, and a mini air compressor.
Old Jun 18, 2011 | 12:42 PM
Silverback's Avatar
depends on the car...
normal car just gets jumper cables, an LED flashlight, a multi tool (cheap knock off leatherman type thing) and one of those flip around 6 way screwdrivers, race car same deal without the jumper cables. Parts chaser/truck/tow vehicle has all that, straps, 30' trucker's chain, a bunch of network cable (use it for tieing stuff down), and my jy crawling tool kit which has a couple of vise grips (one with the 3 sided nut grabbing jaws), a pair of dikes, a cheap socket set that I dont care about loosing...
Old Jun 18, 2011 | 04:32 PM
mpmjason's Avatar
i go to wallyworld and buy those cheap *** mech tool kits to keep in the trunk.
Old Jun 18, 2011 | 06:33 PM
1BAD02WS6's Avatar
do you carry tools to put the belt on?
Old Jun 26, 2011 | 08:59 PM
67RSCamaroVette's Avatar
I carry
1/2" LONG ratchet with a lugnut-sized socket
7mm hex driver
flat+philips tip screwdrivers
10mm, 12, 13, 15, 17mm sockets 3/8 drive
same size ratchet wrenches
Klein crimper/wire cutter
Spare fuses
Maglite
8" and 12" crescent wrenches
Channel locks
Small ball-peen hammer
Duct tape
Fits in my 16x4x6 tool bag no problem (1/2" snap-on flex-head ratchet fits folded inside), never had to call a tow truck.
I drove a '96 S-10 for a while, and I'd never know when I'd have to replace a radiator or pound in a tranny seal on the side of the road, haha. Probably why I carry what I do.
Lots of water bottles on a long (200+mi) trip, just in case.
Old Jun 26, 2011 | 09:03 PM
You don't need tools to put an F-body belt on Left palm pushes on the tensioner pulley, put your weight on it, right hand slides the belt under the water pump pulley.
Old Jun 26, 2011 | 09:05 PM
ScreaminRedZ's Avatar
registered user
I don't carry a general mainainance tool kit in my cars, but I did put together a small tool kit for changing nitrous bottles and jets, that I kept in my Z28.
Old Jun 26, 2011 | 09:18 PM
9802TransAm's Avatar
.357 magnum and cash. Solved every problem I've ever had.
Old Jun 26, 2011 | 10:49 PM
garygnu's Avatar
a tire plug repair kit,plug in 12V lite,and a belt tension wrench for the DD .a 9mm has more in the clip.
Old Jun 27, 2011 | 12:14 AM
Anthony Williams's Avatar
A good set of mechanix gloves, a harbor freight tow rope, a dog bone multi wrench, a multi bit screwdriver, a 24oz. plastic cup, and a tire pressure gauge.
Old Jun 27, 2011 | 12:27 AM
01ssreda4's Avatar
No, but I figure it is a hell of a lot easier to find a set of sockets then a specific belt....possibly in the middle of the night, or the middle of nowhere etc.
Old Jun 27, 2011 | 07:52 AM
ABeasst's Avatar
Belt tensioner wrench, extra belt, and a 9mm with a box of ammo.
Old Jun 27, 2011 | 09:01 PM
grunt1152's Avatar
I have a complete tool set in my car, but thats only due to me working on something every time I turn around. I was getting tired of not having what I needed so I just packed a little bit of everything. Complete set of standard and metric wrenches and sockets, screwdrivers, pliars and vice grips, fuses and electrical connectors. Just a bit of it all.
Old Jun 28, 2011 | 04:41 PM
carcrazed484's Avatar
I have a complete set of tools as well. Just in case anything happens. Better be prepared than sorry
