Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Socket and wrench rust removal?
Old Jul 24, 2013 | 11:39 PM
CMKworm's Avatar
Default Socket and wrench rust removal?
I inherited some tools from my grandfather which are a bit rusty. I tried soaking them in transmission fluid like I read online and it did nothing. I was considering buying some evaporust from harbor freight or a tumbler of some sort. Any ideas? I'd like to get them cleaned up nice.
Old Jul 25, 2013 | 12:00 AM
Blown06's Avatar
8 Second Truck Club
electrolysis?
Old Jul 25, 2013 | 08:30 PM
82cetuner's Avatar
how rusty are they? have you tried sandpaper or a green scotchbrite pad? not sure if your going to be able to clean them up without some elbow grease
Old Jul 25, 2013 | 08:46 PM
CMKworm's Avatar
Some of them are pretty rusty while some are not too bad. There are literally hundreds of them which is why I'm looking for a quicker solution.
Old Jul 25, 2013 | 11:49 PM
Blown06's Avatar
8 Second Truck Club
electrolysis...........google it
or better yet, check it out on youtube.
Old Jul 26, 2013 | 01:25 AM
CMKworm's Avatar
So with the electrolysis I could only do one socket at a time?
Old Jul 26, 2013 | 11:15 AM
jimmyblue's Avatar
Moderator
You could try to reduce the rust, like by plating in a
zinc bath, but this is liable to produce uneven results -
plating will throw harder against the bright areas than
the oxidized. You might like "killed spirits" plumbing
flux as a bath, ZnCl+HCl will go to town on the rust.
A car battery charger with a light bulb for current
limiting (or a current controlled charger) will do for
power. A zinc anode from a marine store is cheap. The
target pieces, you could bag up with a wire snaked
through / around them and do it bulk style, pulling
and shaking the bag every so often. An agitator for
the bath is important, a cheap aquarium bubbler or
a low speed motorized stirrer would probably do. Just
have to keep thinngs from stagnating.
Now the other alternative is to mechanically clean
them as good as you can, and go the other way -
black oxide anodize the iron. That, as I recall, wants
a H2SO4 bath and workpiece positive.
Old Jul 26, 2013 | 02:20 PM
raven154's Avatar
Evaporust works amazingly well and pretty fast too. Just don't leave tem in there and forget about them. It will evaporate and it just leave this really thick nasty stuff behind. As long as you use it right, that stuff is amazing.
Old Jul 26, 2013 | 02:52 PM
SSellers's Avatar
Some good pics here:
http://www.camaros.net/forums/showthread.php?p=1790222
