Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
DIY oil priming under $20
Old 05-16-2015, 03:45 PM
  #41
TipsyMcStagger's Avatar
Originally Posted by NemeSS
good idea.
the bore is a m10x1.5
i know ive seen m10x1.5 male to barb fittings on ebay.
should work
Is that correct? It's not M12 x 1.75?
Tipsy
Old 05-16-2015, 05:56 PM
  #42
tadams72's Avatar
Tipsy
Tipsy I think you are correct. Everything I looked up suggested the same. If I get a chance later I will double check but cross reference on Fumoto states M12 x 1.75 as well.
Old 05-18-2015, 05:18 PM
  #43
I installed my cam about a year ago and left the rockers off so the engine wouldn't sit for a prolonged time with the springs compressed. I spent most of today attempting to install the rockers and to verify that 7.4" pushrods are correct, based on the number of turns it takes to achieve 22 ft lbs from zero lash (see my thread here).
The engine has been sitting for more than two years and I decided I'd try getting some oil in the valvetrain. I ran into town and picked up a cheap mechanical oil pressure gauge. Good thing I already had an
Autometer 2268 metric adapter Autometer 2268 metric adapter
sitting in the parts pile.
Everything worked just fine, except I made a bit of a mess. Oil leaked from where the hose attached to the oil filter nipple and also through the holes in the crankshaft flange (those crank flange holes are open to the oiling system when there are no flywheel bolts installed, correct?)
I barely used two quarts before I decided that was adequate. As reported by the OP, you can easily exceed 60 PSI. I stopped several times (partly to manage the leaking oil) and rotated the crankshaft. This definitely helped and I pumped several times until oil was confirmed flowing from each pushrod as witnessed on each rocker. At one point, oil shot a few feet across the garage!
Simple method. Works well. Thanks for the tip.
Tipsy
Old 05-18-2015, 06:19 PM
  #44
toyin's Avatar
Thanks for sharing! Ill be priming mine soon and will be using this method! I tried the original link but it didn't work. Here's a link that should work and the item number in case the link doesn't work.
http://www.harborfreight.com/heavy-d...gph-62145.html
Item# 62145
Old 08-13-2015, 10:49 PM
  #45
martsink's Avatar
Hey guys,
I just tried this method and failed. I feel like I got a different oil pan or I'm missing something here. If you look at the image below, there's a hole next to the oil filter threads (by the red dot). When I pump the oil, it just drains out of that hole. I would really appreciate some help ASAP as I'm trying to get my engine started tomorrow.
Thanks,
Vlad
Old 08-14-2015, 12:05 AM
  #46
tadams72's Avatar
Originally Posted by martsink
Hey guys,
Thanks,
Vlad
No image Vlad. Send it again.
Old 08-14-2015, 12:09 AM
  #47
martsink's Avatar
well that's embarrassing... I guess it's not as bad as sending an email and forgetting the attachment
Old 08-14-2015, 08:22 AM
  #48
SSSTANG#1's Avatar
Where are you connected to pump oil into the engine? The oil is draining out of the inlet to the filter from the oil pump. Do you have the oil diverter installed in the oil galley from the rear of the block? If so, oil is just getting past the diverter and you will have to plug the hole where oil is leaking.
Or, put a filter on the pan and use the oil galley inlet on the side of the block to pump oil into.
Old 08-14-2015, 08:27 AM
  #49
martsink's Avatar
Filter hole threads like OP
Old 08-14-2015, 08:46 AM
  #50
SSSTANG#1's Avatar
Check my last post...edited.
Old 08-14-2015, 08:59 AM
  #51
martsink's Avatar
Thanks for the input. I'm not really familiar with the diverter. Could you elaborate?
Thanks!
Old 08-14-2015, 11:17 AM
  #52
martsink's Avatar
Worked like a charm once i plugged the hole with a rag and a rubber glove. The pump pretty much exploded as I was finishing up. I sure hope no plastic went into the oil. Wish me luck with the start
Old 08-14-2015, 04:52 PM
  #53
tadams72's Avatar
Damn. How long and how fast did you spin it? I used one for quite a while to drain fuel from my tank and it worked like a charm with no issues.
Old 08-14-2015, 04:58 PM
  #54
martsink's Avatar
I think the pump was defective because it was making a cracking noise from the start. I used a regular hand drill on medium speed for just over a minute. We're you guys getting a steady 45 psi? Mine kept jumping between 35-55, which I also feel like it was due to the pump being faulty.
Old 08-15-2015, 02:08 PM
  #55
tadams72's Avatar
Default DIY oil priming under $20
I haven't done mine yet so can't comment on pressure but definitely didn't have any issues or noises pumping fuel.
Old 10-04-2016, 09:38 PM
  #56
Helomedic1171's Avatar
resurrecting this thread, because I used the search feature...
I have an 03 Lq4 that has the oil cooler lines on it. could I just hose clamp to those to force oil back into the engine?
Old 03-11-2017, 06:53 PM
  #57
pt2285's Avatar
I have a GM crate ls3, can I do this drill pump thing but through the oil port on the front of the block by the pump? Engine already in car.
Old 03-11-2017, 09:24 PM
  #58
tadams72's Avatar
Yes. Run the inlet to the front port and draw from the pan.
Old 03-12-2017, 01:26 PM
  #59
pt2285's Avatar
I get the theory... but why can't I just draw from a jug of oil and let it drain into pan.
Old 03-12-2017, 07:23 PM
  #60
SSSTANG#1's Avatar
That'll work too.
Quick Reply: DIY oil priming under $20
