Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Diy powder coating oven build
Old 09-11-2013, 12:59 PM
Lrn2Go's Avatar
That wet look...
Old 09-11-2013, 01:12 PM
Datankid069's Avatar
Originally Posted by 02BlackBullet
You may also want to look at powderbuythepound.com as well. They have some nice flowing powders. Great work on the oven! I need a bigger oven...big time!
Coating is a blast...or it's a pain in the ***. LoL, here's some covers I did for my IBM GTO.
X2 on a bigger oven, sometimes my conventional oven can be a pain in the a**.
Old 09-15-2013, 01:00 AM
Uneverknow's Avatar
What powder coating guns are you guys using? I want to get into a home set up any help would be appreciated! Awesome ovens guys
Old 09-15-2013, 01:49 AM
CRASHz427's Avatar
Im using the Eastwood gun
Old 09-15-2013, 01:39 PM
Uneverknow's Avatar
Ok thanks, could I use a heat lamp to cure the powder? Does anyone know
Old 09-15-2013, 04:09 PM
trans damm's Avatar
That looks awesome! What color is that?
Old 09-24-2013, 03:58 PM
BLP13's Avatar
this is awesome!!!! great job
Old 09-25-2013, 12:57 AM
xxtremes33's Avatar
that valve cover is beautiful.
i use a eastwood powder coater also. all the parts are looking good so keep up the good work.
Old 10-16-2013, 11:04 AM
RogueFab's Avatar
Trans Damm, That is one good looking valve cover. Wow.
Old 02-12-2014, 07:15 PM
Outlaw666's Avatar
wow this thread gave me some good ideas...thanks for sharing
Old 02-14-2014, 04:07 PM
DopeFedZ's Avatar
Old 03-30-2014, 07:49 PM
  #32
CRASHz427's Avatar
Just finished a set of Weld Magnums for a local friend. Fronts only right now. Will be doing the rears soon. Check it out
Old 08-23-2014, 11:21 AM
  #33
V8Rumble's Avatar
Thumbs up
Man, this is a project that I've given serious thought to many times. Thanks for posting this & giving all of us an idea of what's involved.
Old 08-24-2014, 06:21 PM
  #34
MetalcoreDakLT1's Avatar
think im gunna give this a shot, many chances to make some extra cash in my area if i can do this
Old 08-27-2014, 10:49 AM
  #35
Sentronix's Avatar
Used to do powdercoating, it's a lot of fun. I'd love to get back into it. The only part I hate is the prep! Lots of talent in here
Old 08-28-2014, 12:08 PM
  #36
smurfkiller's Avatar
awesome work guys, crash where are you located in houston?
Old 08-28-2014, 01:04 PM
  #37
CRASHz427's Avatar
SE Houston in Pasadena.
Old 08-30-2014, 02:19 PM
  #38
bbreault's Avatar
That's awesome! Im currently doing a build similar to this. As far as the insulation goes, did you use the regular aluminum backed insulation or I think it was "rock wool" insulation? I only ask because ive read that the regular insulation breaks down due to the heat as to where the later of the ones Ive mentioned do not. As far as powders Ive bought and used powders from Prismatic Powders simply due to the array of powders offered but Im not sure if I like how they flow out so Im gunna buy some other powders eventually. Looks great though!
Old 08-30-2014, 03:03 PM
  #39
CRASHz427's Avatar
I had a hard time finding actual rock wool and when I did it was pricey. I took a gamble on the water heater wrap stuff you can pick up at any Home Depot or lowes and it works flawlessly. At 400 degrees I can place my hand on the oven and it is cool to the touch
Old 08-30-2014, 09:27 PM
  #40
bbreault's Avatar
That's really good to know actually, thank you! I actually haven't looked for rock wool but it's def good to know regular insulation will work!
Quick Reply: Diy powder coating oven build
