Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
SNL Performance/Fabrication Work
Old Aug 22, 2014 | 02:19 PM
SNLPerformance's Avatar
Default SNL Performance/Fabrication Work
Here are some pictures of Patrick's Twin Turbo CTS-V 3" Exhaust we built in house last week. We used Magnaflow s/s tips. 6 hangers, with v-bands for easy removal.
All TIG welded with a Miller Syncrowave 200, 1/16" 2% Ceriated Tungsten, .035 stainless rod, small gas lens, #8 cup, 18-20 pure argon on 45amps
The difficult part of this fabrication job, was clearing the first ever 2nd Gen CTS-V 9" from G-Force! It took a ton of small bends for maximum ground and driveshaft clearance.
Attached Thumbnails SNL Performance/Fabrication Work-close-up-vband.jpg   SNL Performance/Fabrication Work-dual-pat.jpg   SNL Performance/Fabrication Work-fab-ex-pat.jpg   SNL Performance/Fabrication Work-ex-off-car.jpg   SNL Performance/Fabrication Work-under-ex.jpg
Old Aug 23, 2014 | 10:48 AM
Unobtainium's Avatar
Looks good.
Old Sep 3, 2014 | 04:53 PM
Thanks! We just added an equalizer pipe (H-Pipe) So much better sounding.
Attached Thumbnails SNL Performance/Fabrication Work-h-pipe.jpg
Old Sep 16, 2014 | 11:52 AM
smurfkiller's Avatar
nice work
Old Sep 16, 2014 | 03:28 PM
jlcustomz's Avatar
Nice fit & finish.
The average exhaust shop can run something in a few hours, but it takes so much more for it to really fit nice, tuck in & last.
Old Sep 17, 2014 | 09:57 AM
Originally Posted by jlcustomz
Nice fit & finish.
Thanks. I couldn't agree more!! Took almost 2 days to get this wrapped up, but oh so worth it!
Old Dec 16, 2014 | 09:55 AM
Here are some fab jobs we have been squeezing in the shop between all the Cadillac builds
Attached Thumbnails SNL Performance/Fabrication Work-8-weld-alum.jpg   SNL Performance/Fabrication Work-sheet-alum-weld.jpg   SNL Performance/Fabrication Work-tt-vette-ic-pipe.jpg   SNL Performance/Fabrication Work-v-band-weld-tb.jpg   SNL Performance/Fabrication Work-v-band-weld-turbo.jpg
Old Dec 16, 2014 | 09:58 AM
Here are some s/s welding....
Attached Thumbnails SNL Performance/Fabrication Work-tial-y-pipe.jpg   SNL Performance/Fabrication Work-truck-dump-tube.jpg   SNL Performance/Fabrication Work-8-weld-steel.jpg   SNL Performance/Fabrication Work-keg-ss-weld.jpg
Old Dec 16, 2014 | 01:09 PM
Kingsize's Avatar
Looks damn good there Steve!
Old Dec 17, 2014 | 02:03 PM
Thanks!
Old Dec 17, 2014 | 04:43 PM
My6speedZ's Avatar
Did the owner specify that he wanted an H-pipe? I have not heard an H-pipe of an F-body, but I can attest to the sound difference of dual straight back pipes vs one with an X cross-over. I played around with my duals about a year ago going through 3 different variations. He will be much happier with the sound. I have always heard that H's give smoother sound and can say that the X's give a much more exotic/Corvetteish tone over straight out the back.
Old Dec 17, 2014 | 04:57 PM
That is the custom exhaust for one of our TT CTSV builds. The crossover ("H") pipe helps keep the tone in check on these things. Without the "H" it sounds very odd.
Old Dec 23, 2014 | 10:25 AM
Here are some finished up fab pictures at SNL on a T6 Turbo Wagon we helped build. The build up of the turbo kit is under "forced induction" if you would like to see more The last picture is how we got the car delivered.
T6 Turbo
5" Down pipe reduced to 4"
3" Intercooler piping
2.5" mid pipes and Y-Pipe to a singe 4" section
Old Dec 28, 2014 | 12:28 PM
11secLS1's Avatar
Good looking work. Do you guys do custom turbo setups as well as kits?
Old Dec 29, 2014 | 09:37 AM
Yes we can do basically anything you can think of - in house. We can do as much or as little as you need. We have people that let us do the fabrication from scratch with no real idea of what they want, and others that have everything in place and just need the welding done.
If you have an idea we can help you put it together and a guesstamation on price and the route you take.
You can reply, pm us or just give us a shout, we will be happy to help you out.
Old Dec 29, 2014 | 01:30 PM
11secLS1's Avatar
E-mail sent
Old Jan 5, 2015 | 09:36 AM
I sent an email reply, but not sure if you received it..?
Let us know please.
Old Jan 7, 2015 | 12:49 PM
Here are a couple of small things we turned out this morning.
Bills GTO, dipstick bracket
CTSV heat exchanger mounting brackets.
Old Jan 7, 2015 | 05:21 PM
jlcustomz's Avatar
Just letting you know Steve, This thread & a few others you posted on have caused me a lot of extra work;;;;;;;
Guess I got inspired enough to finally build my own custom tri-y headers & put together my own 3" mandrel bent exhaust system. You know the saying, if you want something done right, do it yourself.https://ls1tech.com/forums/generatio...e-headers.html
While mine will be done between my day job & on an after Christmas size budget (some used parts, not all stainless) hopefully when done it will look like fabrication worthy of your shop.
Thanks for the inspiration.
