Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Beaudacious Back Half
Old Jan 31, 2021 | 01:01 PM
2ToeRacing's Avatar
HOLY ****...you have some fukin mad skills!!!
Old Feb 7, 2021 | 08:18 PM
orange88ls1s-dime's Avatar
Thanks but its only because im too damn stubborn to quit
Old Feb 7, 2021 | 09:12 PM
mightyquickz28's Avatar
On something like that fabbed 9" housing, how do you defeat warpage as you construct it? So many times when I'm welding hot and cold sides for my turbo setups, I get all my pie cuts made, mocked up, taped, etc, then do some tacks to hold things in place. But when I start going around the circumference, things start pulling one way or another and by the time I finish, sometimes the v-band flanges don't end up where they were intended. I have to imagine on such substantial pieces as that differential housing, it's even more pronounced. Do you account for the anticipated warpage or pulling by incorporating a gap before you start welding or is it more of a process of balancing a inch of weld on one side, then an inch on the other, , back and forth till it's all welded?
Thanks,
Great work by the way!
Old Feb 8, 2021 | 08:31 AM
Thanks,
thanks for the compliment
This is how i weld housings without distortion
As for tubing systems i do one complete weld at a time that way my distortion is counted for during the next fitting
