Comp cams pushrod checking tool to short?
I'm trying to check what length my pushrods need to be and can't for my life get the numbers to ad up.
So I checked my measurements with my old 7.400" long pushrods and ofc they are to long by about 0.0138". Or maybe I should say, they are that much longer than if I set the tool to 7.400"
I am measuring with one of those machining dial gauge.
And don't worry. I know how to use the dial gauge, I used to be a cnc machine operator.
So.. Is there a reason to why the length checking tool is measuring to short?
Some numbers never hurt anyone.
With the 7.400" pushrod I get 0.0472" of preload.
With the tool set to 7.400" I get 0.0334" of preload.
I'm using comp cams short travel lifters and aim for 0.025" of preload. Does that sound alright?
What pissed me off more than anything was that I bought a china brand one under another name found measured .034 per turn and when I contacted the company that I bought it from they said they got a batch that was wrong so they updated their website... No offer to send me a good one. At that point I figured I would buy the Comp brand and that was the one that was also junk, That seller made it right and sent me a legit comp pushrod checker.
As for method. Sinse it's hard to adjust the tool in place, I adjust it to a length, let's say 7.300" (on the tool) and assemble it with rocker and check for lash. Disassemble, adjust the tool until no lash.
Record the data. Recalculate data based on that the tool is short. Ad 0.015" -0.025" to get suitable push rod length.
I was actually thinking of remeasuring and recording preload on all lifters and using that as well to determine a good push rod length.
Maybe I'm just better off using my old push rods and my dial indicator and just count the turns on my fasteners?
You can then validate preload after you receive your new pushrods.
It's pretty much irrelevant whether or not the checker tool is advertised length. Ignore the "turns to length" method. Measure the length with a caliper instead. I use a bit of teflon tape on the threads so the tool doesn't move on me when handling.
I can however agree on that sinse what the tool says is all wrong, I don't think there would be any better use for it.
Measure length at zero lash and add the preload you want. But that still won't be the length you order. You'll need to call up your pushrod manufacturer (Manton is a good one) and share your measurements and the brand and part number of length checker tool you used. They'll compensate to account for shape of the ends of the pushrods vs. the checker tool, and things like growth of the block after engine warm up. Then they'll group your results according to the length increments they are able to manufacture. You'll likely end up with 4 or more different pushrod lengths when they're done, and you'll need to keep track of which one goes in which hole.
There are three ways manufacturers use to measure pushrods(some change for their different lines of pushrods[comp cams]) you can google it for the descriptions on the 3
Comp cams has two types(not actual tools they have many) of pushrod checking tools that I know of. Each checker is for their line of pushrods and may work for some other brands. That is maybe why your tool isn't exactly 7.400 because their 7.400 pushrod isn't 7.400 total length.
Just be glad your not flat tapped SBC they sized them so you gotta buy two, for example I need checkers 6.8-7.8 & 7.8-8.8
