Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
mig wedler as an arc
Old Aug 11, 2004 | 04:33 PM
Rodonets's Avatar
Default mig wedler as an arc
I am kinda new to welding, i weld a bit but i am really bad at it, need practice. my question is i have a 135 amp ryobi mig welder. I was wondering if i changed the mig gun cable to an arc welder cable would it be possible to use the mig welder as an arc welder? I want to weld a front clip on a 1947 gmc 1/2 truck after i perfect my skills a bit, thanks in advance
Old Aug 12, 2004 | 02:24 PM
jimmyblue's Avatar
Moderator
I think it will work poorly, the MIG does not
give you a constant current. For heavier
gauge welding where you want more
penetration I'd say go with a heavier gauge
flux cored wire with no gas. Whatever is the
biggest your pinch roller and cable feed will
pass.
Old Aug 12, 2004 | 05:00 PM
SJM Manufacturing Inc's Avatar
Not to be a smartass but mig welding is arc welding (gmaw...assuming your setup uses gas)...just a different method...
Why not just mig weld your joints since your welder is set up for it. Even though your welding setup is mean for thinner materials, it should go up to 1/8 inch. If your material is thicker, then just pre-heat the area before you weld.
The main advantage of stick (smaw) welding is in windy areas. It can produce more porosity as well as additional splatter.
Old Aug 13, 2004 | 11:47 AM
Rodonets's Avatar
Cool Thanks, it was just one of those questions that was bugging me, i can just make better weld with my 70 amp arc then i can with the 150 amp mig so just a thought
Old Aug 13, 2004 | 12:14 PM
1fastWS6's Avatar
You can make a better weld with a stick welder versus a MIG???
You're not doing something right with the MIG then.....
