My ultimate garage near completion
Originally Posted by INTMD8
I had the same problem and recently had the garage door raised.
He extended the tracks up along the ceiling, and also raised the opener. In order for the existing opener to work, he had to add an additional section to the top of the garage door (in order to give it something to pull on).
At the same time, he also converted the door from a single spring to a dual spring setup.
I'm ordering a lift tomorrow now that I have enough clearance.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by 88SS LS1
Instead of using a standard garage door why can't you use a roll up door like in some commercial applications.
