Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Where to get a 1/2" drive 8mm socket?
Old Dec 4, 2004 | 11:26 PM
Dope's Avatar
Default Where to get a 1/2" drive 8mm socket?
Impact or chrome, deep or shallow, don't really care.
Seems most tool brands only go down to 9 or 10mm. Anyone know where to get an 8mm?
Dope
Old Dec 4, 2004 | 11:37 PM
boondiggys's Avatar
im guessing they dont make it cuz theres no need for one....where are yuou going with all that torque on an 8mm bolt??
Old Dec 4, 2004 | 11:43 PM
Dope's Avatar
Thanks for the helpful reply.
Did a bunch of digging and found what I needed.
SK makes an 8mm 1/2" shallow impact - part #34058
Proto makes an 8mm 1/2" deep impact - part #7308M
I ended up buying the Proto.
Dope
Old Dec 5, 2004 | 06:18 PM
boondiggys's Avatar
seriously tho can you answer?
Old Dec 5, 2004 | 07:13 PM
mikey's Avatar
LS1TECH Sponsor
Rocker bolts are 8mm and require 22lbs/ft of torque. I would have used a 3/8 drive 6 point. SK / Napa make them.
Old Dec 5, 2004 | 08:24 PM
SPANKY LS1's Avatar
You could have used a $1.00 1/2 to 1/4 adapter, sold at any hardware store. I'm guessing your only torque wrench is a 1/2" drive, correct?
Shawn
Old Dec 5, 2004 | 08:59 PM
Dope's Avatar
Not even close boys.
The tranny tunnel plate on a C5 is held in with 36 8mm bolts. My electric impact makes quick work of it, but it's a huge pain with using adapters and such. They're always seperating and wobbling around. A single deep socket will (hopefully) work much better.
Dope
Old Dec 6, 2004 | 11:02 PM
Louis's Avatar
Cordless drill with a 1/4" adapter in it. Dont have to worry about overtightening them and stripping them going back together
Old Dec 7, 2004 | 09:07 AM
Dope's Avatar
Yeah that's all I need, more power tools outside while I'm working on the car
Plus, the impact is way faster. Makes a difference when you're doing 36 bolts.
Dope
