I found the BEST three-jaw puller finally
I saw this a long time ago at Sears (K-Mart???) for $80. Apperently, it is not a Craftsmutt tool, however.
It looked really well-made but I was wondering if it would hold up given that it has a smallish threaded rod???
Any thoughts on this; has anyone broken one of these?
Originally Posted by Jax White TA
If you are doing a cam change you are going to need to remove the cooling fans and the radiator anyways.
I have to take mine back. It didn't work. Isn't big enough to go over the ASP and since the ASP is solid inside there are no tabs to latch on to. So I used my dads old Snap On 2 jaw set that has various configurations and it fit better than it did on stock. Used it on my stock but fiment was bad but it did the job.
If you're looking for a cheaper alternative try Autozone, OEM #27139 (Great Neck Chrysler Harmonic Dampner Puller). I know it says it's for Chrysler motors, but it works like a charm. After breaking two of their loaner 3 arm pullers on my cam change a few months ago, I decided to give this one a try. Wish I tried it sooner; would have saved me a lot of headaches. Go to their website and search by part number. Good luck!
Drew
This worked on the stock pulley. Not sure if it would work on ASP...
Drew
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
http://cgi.ebay.com/ebaymotors/ws/eB...519749576&rd=1
Don't know if any of y'all have seen this, a good puller at a decent price.
#33
Drew
Drew
#34
wrencher
