Lift questions
Al
i've seen a 2 pole lift with the tops of the poles sticking into a guy's attic. his car was short enough so he could raise it almost to where the car hits the ceiling and sill get under it.
If you think about it you should measure from the bottom of your chassis, not your wheels to the roof of the car and subtract that from your 9' ceiling; you can walk around the tires.
Anyway, I say go for it! You'll love it. It's a HELL of a lot better and a HELL of a lot faster that dicking around with jackstands
Let me know if you have any questions. It sounds like we have the same kind of setup.
If you're going with a two post lift you should contact the lift company and see what they recommend, more then likely you'll need 6"-8" of concrete where the lift base is anchored. With a four post like mine you only need 4" of concrete, personaly I like a four post lift over a two post lift. You'll want a 12' ceiling and if you're lift a truck or SUV you may want something like 14' instead.
I don't know if it is a lot more expensive to have a 14' insulated ceiling, but if not I would go for it. You definitely can't walk under vans with a 9' ceiling.
Thanks!!!!!!!!!!!!!!!!
My drill bit only cost me $10 anyway.
Just my .02.
