Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
TIG welding help
Old May 15, 2005 | 09:23 PM
kozak's Avatar
Default TIG welding help
Hey guys i am going to need to start tig welding soon is there instructions online or some where i can brush over to get started.
Old May 15, 2005 | 10:03 PM
Anti-Venom's Avatar
ohhhh.....I'd say your best bet is to take a college class on Tig welding if possible. Sounds like its for your job or something, so I dont know if you'd have enough time to do that.
Its all about concentration. I've taken several classes at the local college in tig, and it took me a little while to get the hang of it. Its not TOO hard, but takes some practice. Its all about applying the right ammount of heat with the foot pedal and having steady hands. As for instructions online, I dont know what to tell you except for searching for stuff on a search engine.
Old May 15, 2005 | 10:33 PM
Mangled03gmc's Avatar
Baltimore Whore
best thing to do is get some scrap and just start welding it togather.Thats how i started(learned). Don't get any better then hands on
Old May 15, 2005 | 10:51 PM
ACW's Avatar
ACW
You'd probably get more suggestions in the Tools forum than in the Lounge... going to send this over there
Old May 16, 2005 | 06:41 AM
BTL FED's Avatar
http://www.hobartwelders.com/mboard/
http://www.millerwelds.com/education/tech_articles/
Old May 16, 2005 | 09:34 AM
kozak's Avatar
yeah don't have time to take any classes it is for a race competition through school. I think that i am going to read what i can but mainly mess around till i get it right, my main concern was for setting up the machine.
Old May 21, 2005 | 03:23 PM
kozak's Avatar
i just tried messing around today and i can smoethines get an arc but have trouble holding it, also i am anialating the electrode and ideas on how to set up the machine.
Old May 21, 2005 | 04:15 PM
Brady's Avatar
LS1Tech Sponsor
are you welding aluminum or steel?
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old May 21, 2005 | 08:14 PM
kozak's Avatar
i was trying alum, just to test out the welder.
Old May 28, 2005 | 08:18 PM
1redta's Avatar
Default re
hey man I think it is easiest to try some stainless then some regular carbon steel and then after some practice and you learn how to adjust the polarity and gas I would go after aluminum Just my.02
Old May 28, 2005 | 09:44 PM
kozak's Avatar
yeah i have been practicing for like 2 days now and i read some stuff online from miller adn i got some good ideas i am using alum cuz i only have tungsten electrodes for alum right now. adn for the stuff i'm welding i think that i have an electrode that is to small i don;t think i am getting enough penetration, prob need to step upto a 3/32 size tung.i'll keep practicing and will keep asking questions.
Old May 28, 2005 | 09:53 PM
Muffracing's Avatar
Make sure you have the machine set to AC for aluminum. If you leave it on DC+ you will melt the Tungsten.
Old May 31, 2005 | 02:07 PM
smokinHawk's Avatar
welding aluminum is alot harder then carbon steel, i started out with carbon steel, welded on refrigerators for about 3 years, then had to relearn to weld when i started welding aluminum.
main thing on aluminum you have to get your setting right adjusting the pulse frequency and penetration., next you need to learn how to get the puddlie flowing and apply your filler right.
Old May 31, 2005 | 06:38 PM
kozak's Avatar
now when you say flowing do you mean liquid and running, what i do is i start the weld get a puddle (mind you this is on a flat plate no joint or anything) add some filler (it usually just sits there in a little ball) press on the peddle a little till the filler spreads out then i ease off the peddle let a skin form on the newly added material, and start the process over. am i doing this right?
Old Jun 11, 2005 | 05:15 PM
kozak's Avatar
bump.
Old Jun 11, 2005 | 06:05 PM
jdustu's Avatar
i believe that "film" you're talking about is oxidation, not good for the weld....you want to keep it going as much as possible, going on and off the peddle or messing with the pulse but not stopping the gas flow completely...
Old Jun 14, 2005 | 06:35 PM
kozak's Avatar
well it's not film its just the metal cooling it changes from the super shinny liquid metal to dull hardened metal.
Old Jun 15, 2005 | 07:37 PM
Louis's Avatar
Check out the hobart welding forums, or the Ask andy forums @ Miller motorsports. They have very good info.
