Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Valve spring tool
Old May 18, 2005 | 02:35 PM
Shon Herron's Avatar
Default Valve spring tool
I need one to do LT1 stuff, anyone got one like I have seen for the LS1 stuff?
Old May 18, 2005 | 03:50 PM
Jeffs99SS's Avatar
Crane makes an LT1/SBC version of their tool. I have the LS1 tool, and it's very nice.... does 2 springs at a time, and has tons of clearance for the back of the motor. Check out their website.
Old May 18, 2005 | 03:57 PM
Crane's is $122, I was hoping to find something a little less expensive.
Old May 19, 2005 | 10:16 AM
gto69judge's Avatar
Default use Tim's Tool
Tim's tool will work on any small block chevy (and many other makes) as well as the LT1. Just enlarge the stud hole with a drill bit. You may need to use a 3/8 or1/2 drive socket as a spacer between the end of the tool and the rocker cover rail, but I have used it on many small block Chevy, Ford, and Mopar heads.
The best part is that it only costs $30. You will find Tim's tool to be one of the best tools in your toolbox!
Old May 19, 2005 | 10:18 AM
Link to tim's tool?
Old May 19, 2005 | 10:19 AM
https://ls1tech.com/forums/tools-fabrication/317675-tim-s-valve-spring-tool-now-available.html
