Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Post pics of your garage / shop
Old 01-27-2007, 05:10 PM
  #141
Irocss85's Avatar
oh, looks very cool. wonder how that could be insulated? where did you get the kit from?
Old 01-28-2007, 12:40 AM
  #142
2MuchRiceMakesMeSick's Avatar
I want this floor in my garage.
Where did you get it?
Old 01-28-2007, 02:50 AM
  #143
SIK02SS's Avatar
Originally Posted by jester1
holly s&*t sik02ss, may be you have some room to spare for me. Its kinda cold up here. I promise I wount take up space ill even sleep in the boat. Land must be abundant out west, with a 4:1 ratio to house you must take up a block or two.
3.5 acre lot...not really in-town, 5 min outside of so theres land to spare
Old 01-28-2007, 06:07 AM
  #144
Chewy72SS's Avatar
Work in progress...
50'x50'
Old 01-28-2007, 05:22 PM
  #145
Sweet71's Avatar
Nothing too fancy but it gets the job done.
Old 01-29-2007, 08:35 AM
  #146
FASTFATBOY's Avatar
You referring to mine?
If so there are many ways to insulate it, they would have insulated it for $1000, it never REALLY gets cold in Mobile Ala, well it DOES because it is so wet and damp here. The builder uses some stuff that looks like plastic with bubbles in it, kinda like a mini version of packaging stuff you see when you get car parts. I decided not to insulate, just gonna buy me a heater to take the chill off. But if I ever decide to, they make panels like sheetrock you can cut and put up, use pink panther vertically and staple it to the 2x4's.
There is a company here in Mobile called Dixie Building Supply, They make the steel and kit. Went up fairly easy(I watched) they buried the poles in the ground, pured the slab around them, the trusses came pre-fab, metal came pre-fab for the most part.
I wanted a "shop" not a "garage"...a garage is like the post above with the three cars sitting in it from the rear..I wanted a "working" shop.
Shop around before you buy, get the local "Penny Pincher" or similar little sale paper, usually have alot of metal building suppliers and erectors in them.
David
BTW there are some guys in here with some NIIIIICE shops!!!!!!
Old 01-29-2007, 08:36 AM
  #147
FASTFATBOY's Avatar
SWEET 71
How wide is yours? How wide is the door? How deep?
Old 01-29-2007, 11:10 AM
  #148
superchargedbandit's Avatar
I Have Pictures But Dont Know How To Download Them. How Do You Do That?
Old 01-29-2007, 11:19 AM
  #149
BonzoHansen's Avatar
It looked likethis right after I epoxied the floor.
Old 01-29-2007, 01:01 PM
  #150
...with cheese.
Armageddon's Avatar
I'm workin on a chub from some of these pictures. I'm gonna go take some pictures of our shop that's being built.
Old 01-29-2007, 02:09 PM
  #151
Sweet71's Avatar
FASTFATBOY
The Garage is 24 wide and 22 deep, i believe the door is 9x20... gets a little tight with both cars in it
Old 01-29-2007, 06:21 PM
  #152
Irocss85's Avatar
yep. thanks. thats prolly the route I'll go for my "shed". little smaller though to fit my city ordinances. I can fit a 15x30 still. or some variation of that size. 20x25 maybe.
chris
Old 01-30-2007, 12:33 PM
  #153
FASTFATBOY's Avatar
chris
Go as deep as you can, at least 30. If you pull an engine from the front with a puller you will have room to maneuver the crane around without fighting the wall behind you.
David
Old 01-30-2007, 05:37 PM
  #154
Irocss85's Avatar
yeah, I know all about that. my garage is 29' deep. perfect for my bench/table, about 8 feet of room, then where the car goes. and that still leaves enough room behind the car for stuff. I got a hoist in my garage. see my very unorganized/crammed garage pics somewhere back in this post. when I took those pics, I was in the middle of an engine swap, AND I brought back a bunch of stuff from storage and had yet to make room for it in my house/basement. I do have all my space back now, but its still not clean and tidy. stuff all over the work table, shelves, floor, stacked against the wall, and so on. thats why Id like to build a large "shed". to keep all the normal crap out there, and let me have my garage just for my work and tools.
Old 02-03-2007, 04:55 AM
  #155
Silverback's Avatar
Anyone ever figure out what the minimum depth you need to pull an engine out of an f-body using a standard folding engine crane? How about engine and tranny as one piece? I think I’ve got something in the range of 22-24’ and I don’t think I can do it, but I’ve never had everything pulled out of the way and tried it.
I’m probably going to get stuck doing it 2x this spring (stripping the parts car, and then putting the engine/tranny in the new project car), and I’m wondering if there is any way I’ll pull this off without pissing off the neighbors.
Old 02-03-2007, 07:06 AM
  #156
lethal93ta's Avatar
my garage is 25x25, I have a 24 inch deep bench in front of the car I could just sneek the engine crane around, I only have about 2 feet in front and in back of the car.
Old 02-03-2007, 09:10 AM
  #157
Irocss85's Avatar
my old garage was only 21feet deep, and I was able to do it that way. it was tight, but it worked. several cars/eng.s that way. one time I removed eng/trans/cradle out the bottom in that garage too. you have to work at an angle when pulling out, and the eng/trans will actually be comeing out over the fender, not the front nose. know what I mean? so the other bay has to be open though, obviously. if you got two cars apart in there, your SOL unless you do the out the bottom. BTW, if your stealing the eng/trans out of a parts car, then why on earth not remove the eng/kmember/susp. as one assembly? you can have it all out in about 4 hours if you take your time. then once that is all out of the way, make a wooden extension for across the front, and set it down on a couple dollys to roll it out and have a flat bed pick it up from a junk yard. thats what I would do.
Old 02-04-2007, 05:56 PM
  #158
sunsetta's Avatar
Don't worry about the neighbors, they'll get over it or move. You have a job you want to do.
Old 02-05-2007, 02:40 AM
  #159
Silverback's Avatar
Well, instead of muddying this thread anymore, I started a new one about garage space and pulling an engine here:
https://ls1tech.com/forums/showthrea...47#post6386747
Old 02-11-2007, 01:22 PM
  #160
NASTYTRANSAM's Avatar
I have either shop to choice from, 38 lifts total.... It helps to be a manager at the Largest used car sales/service departments in Indiana. I have worked at both locations and there both only 10 minutes from home....
Quick Reply: Post pics of your garage / shop
