Pep boys engine hoist warning
Check this out. Guy was lifting his BBC with a Pep Boys hoist, on the 1.5 ton setting...
http://67-72chevytrucks.com/vboard/s...d.php?t=194915
Bent the frickin hoist. Wow.
huh, there's something weird going on there...
Yes, it is designed wrong, but I'm pretty sure that that tube should be able to handle the load of a big block without all the bracing...
Well my kragen one didn't bent but the seals are shot meaning to keep the motor in the air i have to continue pumping it to keep the engine from falling..I know I was buying cheap stuff but owe well...
