Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Test the compression ratio of any engine
Old May 22, 2006 | 01:46 PM
Katech_Jason's Avatar
LS1TECH Sponsor
Default Test the compression ratio of any engine
Static engine compression ratio meter
The WHISTLER is an electronic device that instantly determines the compression ratio of virtually any engine.
Using the WHISTLER is easy, just remove a spark plug and screw the WHISTLER adapter in its place. Enter the number of cylinders, CID, and temperature of the engine into the WHISTLER. Then, bring the engine to TDC and the unit will display the compression ratio to the nearest tenth of a point.
All you need is a low volume air source and a 120V AC supply
• Works with 4, 6, or 8 cylinder engines
• Cubic inches from 6 to 600
• Engine temperature range 30 to 200 deg f
Included with the WHISTLER
• FN, BN, BL, J and 18mm spark plug adapters (12mm motorcycle available)
• Verification bottle (allows you to check the accuracy of the unit at any time)
• Easy to understand instruction sheet
The price of the WHISTLER is $1,995.00
Old May 22, 2006 | 10:33 PM
slowpoke96z28's Avatar
where else have i seen one of these?
Old May 23, 2006 | 07:41 AM
LS1TECH Sponsor
A lot of circle track sanctioning bodies use them to check for people breaking the rules on compression ratio limits. We are the only company that makes a product like this.
Old Sep 19, 2006 | 10:46 AM
LS1TECH Sponsor
For anybody looking, we were backordered - now back in stock.
