Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Basic tools for the novice mechanic.
Old Jun 9, 2006 | 10:54 PM
Diamond Jim's Avatar
Talking Basic tools for the novice mechanic.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, splattering it against that
freshly-stained heirloom piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under
the workbench with the speed of light. Also removes fingerprints and
hard-earned guitar calluses from fingers in about the time it takes you
to say, "Ouch...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VISE-GRIPS: Generally used after pliers to further round off bolt heads.
If nothing else is available, they can also be used to transfer intense
welding heat to the palm of you r hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside
the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or 1/2
socket you've been searching for the last 15 minutes.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new brake shoes, trapping the jack handle
firmly under the bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward
off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
drill bit that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength on
everything you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large pry bar that inexplicably
has an accurately machined screwdriver tip on the end opposite the
handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a
drop light, it is a good source of vitamin D, "the sunshine vitamin,"
which is not otherwise found under cars at night. Health benefits aside,
it's main purpose is to consume 40-watt light bulbs at about the same
rate that 105-mm howitzer shells might be used during, say, the first
few hours of the Battle of the Bulge. More often dark than light, its
name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids
and for opening old-style paper-and-tin oil cans and splashing oil on
your shirt; but can also be used, as the name implies, to strip out
Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty
bolts which were last over tightened 50 years ago by someone at Ford,
and neatly rounds off their heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate the most expensive parts not
far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well
on contents such as seats, vinyl records, liquids in plastic bottles,
collector magazines, refund checks, and rubber or plastic parts.
Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage
while yelling "DAMMIT" at the top of your lungs. It is also the next
tool that you will need.
EXPLETIVE: A balm also referred to as mechanic's lube, usually applied
verbally&nb sp;in hindsight, which somehow eases those pains and indignities
following our every deficiency in foresight.
Advanced mechanics will have more expensive tools which can be used for a quicker death and distruction.
Old Jun 9, 2006 | 11:32 PM
mrhzk35404's Avatar
Dup.
Old Jun 10, 2006 | 12:08 AM
JPMuscle's Avatar
that was pretty good tho . lol
-john
Old Jun 10, 2006 | 03:48 PM
AGRV8D's Avatar
Old Jun 10, 2006 | 04:55 PM
WhiteStripes's Avatar
LMAO @ Dammit tool.
Old Jun 14, 2006 | 05:46 PM
HeapaShifter's Avatar
TTT. Because I like this thread.
Old Jun 14, 2006 | 08:14 PM
69chevy's Avatar
I thought it was going to be something serious and stuff. Good ones.
Old Jun 15, 2006 | 05:51 PM
FlashLCD33's Avatar
This guy's good
Old Jun 16, 2006 | 05:01 AM
jlm44's Avatar
nice bro! ttt
Old Jun 16, 2006 | 06:08 AM
2000SS1979's Avatar
I loved it.. Only because its true.
